MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
lvpokka
Post by lvpokka »
[mention]mellps[/mention]
Your not even trying)) hope you can figure it by yourself.
p.s this post is not for helping, create new topic.
mellps
Post by mellps »
lvpokka wrote: 04 Aug 2019, 21:37
@mellps
I switched the X and Y values on the first number, and the minutes images to the small ones, I forgot to change it back before uploading... The numbers won't appear at all, not even in the wrong place, like in your image, so I was changing anything in the hopes something would happen to help me figure out what was wrong...
But thanks for looking at it, anyway
Urimu
Post by Urimu »
lvpokka wrote: 04 Aug 2019, 18:28
You should follow the order in json.. each next image index set should be HIGHER then index used above(or you can reuse already used indexes from above)... i will add this feature in 1.3.8.
Its simple to follow only two rules
Hi again, I do follow those two rules. Here are the files I don't know what am I doing wrong
Removed the link
There is a space before .com I coudln't post it any other way. BTW both versions return the same error.
And I want to ask you, what is that program in the screenshot you sent to mellps?
lvpokka
Post by lvpokka »
Urimu wrote: 05 Aug 2019, 08:53
https://drive.google.com/folderview?id= ... i6RhPExqma
remove 22-42 images. your not using them!!!!! you have gap in images because of not using them.
Battery -> Text why there is 0 everywhere??? remove if not using it
your animation images weight is more than 300... after builing bin you should have <320kb for valid watchface
p.s. just builded this wface, size is 781) it will never work. also images of animation is TOO heavy and it cannot be stored in palette mode
p.p.s "that program in the screenshot" it's only for debugging, not for public release for now.
Urimu
Post by Urimu »
lvpokka wrote: 05 Aug 2019, 09:15
I have had the feeling that it has to be something with the size of the files, thank you for clearing that up. Maybe the error should have said something like images too big, but again thnak you I will try to re-do it correctly
Alby128
Post by Alby128 »
Hi, thanks for this amazing software. Is there a way to switch the date format from MM/DD to DD/MM if the date is set using MonthAndDay->OneLine? This would be of great help for all the languages with this date format.
Alberto
lvpokka
Post by lvpokka »
Check other working WF as an example, there is two ways how to define Dataformat
Alby128
Post by Alby128 »
Yeah, I know about the Separate structure, but I would still like to use the automatic separator (which is also movable in case you want to use one digit months). Would that be possible?
lvpokka
Post by lvpokka »
No idea about this) if you will get this information somehow, please let me know )
yinas
Post by yinas »
lvpokka wrote: 04 Aug 2019, 15:10
Weather is not supported by Miband4 itself, at all, for watchface...
You wanna tell that you have working weather watchface?
well at least the generated preview shows the weather icon and temperature number. one would assume that if that is shown, it would also reflect on the actual installed watchface...
also
What's new
removed color restrictions for images
(from your headline post)
what does "fixed weather" mean in this context then?
lvpokka
Post by lvpokka »
Preview)) we suppose that it will be supported in future.
terminal
Post by terminal »
I'm having trouble with the preview not matching what shows on the watch itself. Everything looks fine in the preview, but on the watch, the battery bars, weekdays, and flags for DND, BT, and lock are missing. Any idea what's going on here?
Here's the preview, directly from the tool, v1.38:
Clarity 2.0_packed_animated.gif (97.32 KiB) Viewed 22062 times
Here's what actually shows up on the watch:
messed up clarity2a.jpg (121.21 KiB) Viewed 22062 times
Clarity 2.0_packed.bin
(100.06 KiB) Downloaded 181 times
fprietog
Has thanked: 10 times
Post by fprietog »
terminal wrote: 06 Aug 2019, 19:34
Try changing Y coordinates to 1 instead of 0.
terminal
Post by terminal »
fprietog wrote: 06 Aug 2019, 20:16
Thx for the hint, but it didn't change anything.
Also, it's odd that rebooting the device messes up the display even more:
messed up clarity2c1.jpg (231.69 KiB) Viewed 22054 times
lvpokka
Post by lvpokka »
[mention]terminal[/mention] wtf? Weekdays should be 21 in stead of 7... first seven is China next 7 is Norml China and next 7 images is english or all other languages
Battery json object missing first block
"BatteryConfig": {
"BoxWidth": 0,
"Alignment": 0,
"Order": 0
+ battery images count is 9 not 10
... never mind
you have ALLOT of errors, please take different or read manuals how to work with jsons
This is not a good topic for your question, create separate one
terminal
Post by terminal »
lvpokka wrote: 06 Aug 2019, 21:46
@terminal wtf? Weekdays should be 21 in stead of 7... first seven is China next 7 is Norml China and next 7 images is english or all other languages
"BatteryConfig": {
"BoxWidth": 0,
"Alignment": 0,
"Order": 0
... never mind
Thx for the info on the battery. This also fixed the status flags. After reading both the readme and your comment, the weekdays are still a bit confusing. Perhaps something is lost in translation. It seemed reasonable to set the WatchFace.exe.config to 0 and use 7 images, as I've seen done elsewhere. The (rather inelegant) fix seems to be padding a total of 21 images with WatchFace.exe.config set to 2.
BTW, the number of battery images is 10 and the topic seems entirely appropriate.
While I recognize that I have a lot to learn about JSONs, perhaps you should also recognize that you have A LOT to learn about communicating in *E*nglish. A good starting point would be googling "polite".
lvpokka
Post by lvpokka »
This topic about WFTool, and all messages are looks like that something is not working properly in my tool... so Good behavior is create new topic under English > Mi Band 4 with your question...
Anyone new who get here for Tool read this and trying to copy wrong or mistaken jsons files as an example.
Urimu
Post by Urimu »
[mention]lvpokka[/mention]
I wan't to ask if there are any plans on implementing "BottomRight/LeftX/Y" as coordinates for the battery meter?
My theory is that you could use imges of different size, thus save space and they would remain aligned, you can do this to some extent now but this would be really helpful
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Discussion topic created all the questions regarding watch faces will be moved here viewtopic.php?f=25&t=797
lazimk
Post by lazimk »
I would like to ask what does 'Order' parameter for Status Icon , battery bar and other elements mean.
What are the changes if i change them.
Second question, does order (in json) of elements affect rendering of watchface, i mean element mentioned on bottom of code rendered(drawn) as a top layer compared to element mentioned on top in the code?
-Laz
*Have a great day*
Urimu
Post by Urimu »
lazimk wrote: 18 Aug 2019, 03:07
IDK about the "order" parameter, but the order of elements in the json does nothing
Titerinho
Post by Titerinho »
Hey guys, I'm having trouble with temperature on my watchface. I have a font that's 12 pixels high, so I created images with "-" and "°C" that are also 12 pixels high, but for some reason this is how the watchface is rendered (left is actual, right is how I want it to be):
It looks like the images are aligned to top left (always) and even though they take up space as if they were normal, they are shrunk to 3rd of their size... This is my JSON:
  "Weather": {
    "Icon": {
      "CustomIcon": {
        "X": 26,
        "Y": 51,
        "ImageIndex": 95,
        "ImagesCount": 26
    "Temperature": {
      "Current": {
        "Number": {
          "TopLeftX": 63,
          "TopLeftY": 60,
          "BottomRightX": 0,
          "BottomRightY": 0,
          "Alignment": "TopLeft",
          "Spacing": 1,
          "ImageIndex": 52,
          "ImagesCount": 10
        "MinusImageIndex": 121,
        "DegreesImageIndex": 122
I tried changing the BottomRightX/Y, Alignment, Spacing and nothing works...
Does anyone have any idea what may be wrong? Tool version 1.3.8. Thanks!
TXK
Has thanked: 149 times
Been thanked: 97 times
Post by TXK »
copy the [font that's 12 pixels]PIC, Paste Into "-" and "°C" and ...... edit it
Make them("-" and "°C" ) the same height and width as the font
Titerinho
Post by Titerinho »
You're right - I don't know how, but I created those images again and now they work, the preview is fine.
But before I put temperature there, my Mi Band was displaying the weather icon. Now when the temperature is fixed in preview, my Mi Band doesn't display the weather icon or the temperature at all... Any ideas?
lvpokka
Post by lvpokka »
Weather was not supported by MiBand4 for now
