Page 6 of 10
Posted: 17 Nov 2020, 10:03
by GIK-Team
In this topic, you may report a problem with our AmazFaces app for
Android.
App version (Stable or Beta)
Watch model
Phone model
OS version
Description of your problem
Filling example:
App version: 2.0.111 Stable
Watch model: GTR
Phone model: Samsung S10
OS version: Android 10
Re: AmazFaces for Android [Support]
Posted: 01 Jul 2022, 22:30
by Julien
Stas wrote: 24 Jun 2022, 08:10
We will download a new beta version soon, the strange behavior has already been fixed.
Any forecast when this will be released? Thanks in advance
Posted: 04 Jul 2022, 13:10
by razenxc
App version: 3.6
Watch model: Mi Band 6
Phone model: Redmi Note 9
OS version: Android 11
Hello, How to solve the problem that when you try to install the dial, it writes "couldnt sync", I use "Mi Fitness" app.
Posted: 22 Aug 2022, 05:40
by Trurl
App version: 3.6.220
Watch model: T-Rex 2
Phone model: Pixel 4a
OS version: Android 12
Hello.
Can't set up any custom face.
The procedure you've described as manual is not working for Android 12.
Would you be able to direct me to the description of the proper procedure?
Thanks in advance.
Posted: 22 Aug 2022, 08:17
by Stas
Please update the app, you are using an old version.
sHawTY wrote: 21 Feb 2021, 13:41
App version: 2.3.130
Watch model: GTR 1
Phone model: Pocophone F1
Sync stopped working again, even when discoverable is enabled
Removed watch from AmazFaces & it still doesn't work
Posted: 08 Sep 2022, 15:38
by lcsbrc
App Version: 3.6.220
Watch model: T-REX 2
Phone model: Samsung Galaxy Note 10
AW App connects to watch (auto or manually). Select the face, select version, click yellow button "Set on watch", Make sure of model and press "Continue". Yellow button "Set on watch" dissapears and
file name and file size are displayed on phone but nothing happens at all.
No watchface uploaded to watch.
Thank you!
Posted: 08 Sep 2022, 19:48
by lcsbrc
Trurl wrote: 22 Aug 2022, 05:40
Hello.
Thanks in advance.
I´ve found a way to upload watch faces to T-Rex 2 using "Amazfit GTR 3 watchface" app on your android phone.
First, on a PC, you have to download the watch face .zip file and transfer it to your phone. (GTR3 or T-REX2)
Open Amazfit GTR 3 WF app
In Menú, choose GTR 3 as your device.
In Menú choose "Install own watchFace"
Brownse and choose the .zip file
Click on "Add WatchFace to Zepp" and ready.
You can also choose any of the watchfaces listed in the app and install directly without having to download to a PC and transfer to your phone.
Posted: 08 Sep 2022, 20:56
by GIK-Team
lcsbrc wrote: 08 Sep 2022, 19:48
Actually, you can add a local file with our application. Just update to the latest beta version.
Posted: 13 Sep 2022, 06:36
by liyongyong
应用程序版本:3.3.196
手表型号:GTR 3
手机型号:redmi k40s
操作系统版本:Android 12
程序总是提示错误,闪退
java.lang.IllegalStateException: Already resumed
at o.r.i.resumeWith(SourceFile:5)
at com.amazfitwatchfaces.st.ktln.ExtensionsKt$auth$2$3.onFailure(SourceFile:1)
at d.g.b.d.m.p.run(SourceFile:5)
at android.os.Handler.handleCallback(Handler.java:938)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loopOnce(Looper.java:210)
at android.os.Looper.loop(Looper.java:299)
at android.app.ActivityThread.main(ActivityThread.java:8205)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:556)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1045)
Posted: 13 Sep 2022, 07:28
by GIK-Team
liyongyong wrote: 13 Sep 2022, 06:36
应用程序版本:3.3.196
手表型号:GTR 3
手机型号:redmi k40s
操作系统版本:Android 12:
This is super old version
Posted: 14 Sep 2022, 02:09
by liyongyong
那最新的版本是多少了?能否设计个能自动更新的程序呢
最新的版本在哪里有下载?
Posted: 14 Sep 2022, 08:52
by GIK-Team
liyongyong wrote: 14 Sep 2022, 02:09
最新的版本在哪里有下载?
It’s automatically updates via Google Play
https://amazfitwatchfaces.com/awapp
Posted: 15 Sep 2022, 04:03
by liyongyong
Google Play中国无法访问,还有其他的下载链接吗?
Posted: 15 Sep 2022, 08:02
by GIK-Team
liyongyong wrote: 15 Sep 2022, 04:03
Here you can download the most current version (it does not update as fast as on Google Play)
https://www.apkmirror.com/apk/gik-teams-web/amazfaces/
Posted: 16 Sep 2022, 00:49
by liyongyong
好的,谢谢
Posted: 16 Sep 2022, 20:13
by Cooperphile
App version: 3.7 Beta
Watch model: T-Rex Pro
Phone model: Google Pixel 3a
Program hangs on first screen. Touching the drop down list does nothing.
- Screen Shot
- Screenshot.png (324.12 KiB) Viewed 11680 times
Posted: 16 Sep 2022, 20:35
by GIK-Team
Cooperphile wrote: 16 Sep 2022, 20:13
We've fixed this known issue, but Google won't let them become live.
Posted: 17 Sep 2022, 17:48
by Cooperphile
GIK-Team wrote: 16 Sep 2022, 20:35
Posted: 17 Sep 2022, 18:43
by GIK-Team
Cooperphile wrote: 17 Sep 2022, 17:48
237 (3.8) Now Live!
Posted: 17 Sep 2022, 21:38
by Cooperphile
Posted: 05 Oct 2022, 14:50
by stldrgn7
App version: 3.8 Stable
Watch model: GTR L 47mm
Phone model: Samsung S20 FE
Not able to sync watch faces to zepp. No error message on Screen. Status progress bar not moving.
Posted: 05 Oct 2022, 17:40
by GIK-Team
stldrgn7 wrote: 05 Oct 2022, 14:50
App version 3.8.250?
Posted: 05 Oct 2022, 18:06
by stldrgn7
GIK-Team wrote: 05 Oct 2022, 17:40
App Version 3.8 (Play store version).
the version 3.8 (250) from apkmirror have the same problem for me.
Posted: 05 Oct 2022, 18:19
by Stas
Fixes for GTR L 47mm will be in the next update few days
stldrgn7 wrote: 05 Oct 2022, 18:06
Posted: 02 Nov 2022, 14:28
by roigreenberg
App version: 3.9.262 Stable
Watch model: GTR 3 Pro
Phone model: Oneplus 8 pro
Hi.
I created a watch face using the editor, and I tried to install it but it doesn't manage to install it.
I tried both as a local file and uploaded it to the could.
I had no problem installing an old face I had.
Posted: 02 Nov 2022, 17:58
by Stas
When does the error occur at the beginning or end of the download?
roigreenberg wrote: 02 Nov 2022, 14:28
Hi.
