Page 5 of 20
Posted: 07 Mar 2021, 10:37
by SashaCX75
Version 7.3
Fixed known display bugs.
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
Added English translation.
v 1.2 Added Spanish language
Donate to the author - PayPal:
[email protected].
Posted: 07 Apr 2021, 10:49
by spidercrab
Just wanted to say that I really hope that there are enough similarities between the T-Rex Pro and GTR 2(e), GTS 2 that eventually, the v2 WF Editor will have the capability to work with the T-Rex Pro.
Having used the v1 Editor with 42mm and 47mm GTR, I have total confidence in SashaCX75 to make this happen if it possible. SashaCX75 is a genius and has given so much to the Amazfit community..
I predict huge success for the T-Rex Pro.
Posted: 07 Apr 2021, 14:04
by SashaCX75
ntnntp
I sometimes have problems installing watch faces. The following actions help:
1 Remove unnecessary watch faces from the watch.
2 Restart the watch.
3 Restart your phone.
If the id replacement did not work, then the dial would be installed but replace the already installed one. Therefore, the problem is not the replacement of id.
Posted: 07 Apr 2021, 14:25
by RufusLoacker
I'm looking into buying a GTR2e, and I wonder if it was possible to create a 24 hours analog watch face (where the hours hand makes one complete round in a day instead of two rounds).
Is this possible to code with this (or other) tool?
pic for reference:
Posted: 07 Apr 2021, 14:45
by SashaCX75
No, the behavior of an analog clock cannot be changed.
Posted: 07 Apr 2021, 19:52
by synar
Dear Sasha!
Just came the fresh firmware for the GTS 2e, and unfortunetely now already the weather alignment issue is arrived to this watch too. Only the left alignment is working properly now. I just want to inform you.
Posted: 08 Apr 2021, 12:50
by wing0826
HI~everyone,
does it only have 12-hour clock in GTR2 watchface?
Posted: 08 Apr 2021, 14:24
by SashaCX75
synar wrote: 07 Apr 2021, 19:52
Dear Sasha!
Thanks for the info. It will be necessary to check, maybe something else has changed.
Posted: 12 Apr 2021, 07:55
by SashaCX75
GTRtoGTR2
Not all elements work after conversion. Of the advantages of such dials, I consider only working shortcuts and the ability to set different fonts and independent coordinates for tens and units in time.
Posted: 12 Apr 2021, 07:58
by SashaCX75
Posted: 12 Apr 2021, 08:51
by spidercrab
This is very exciting.
Does this convert from GTR2 to T-Rex Pro? Or can I load a GTR47mm WF and convert to T-Rex Pro?
Also there are 2 versions in the 2 posts above. Which is the best to use?
Posted: 12 Apr 2021, 10:45
by SashaCX75
Can convert T-Rex to T-Rex Pro
If you need to convert GTR47mm to T-Rex, you can do it in the editor for GTR47mm
Dials created by conversions from GTR47mm are not compatible with WatchFace editor 2. I have posted these programs here because they create dials for the same models as WatchFace editor 2. Further development of these programs is not planned and therefore I did not become a separate topic for them on the forum create.
Posted: 12 Apr 2021, 14:54
by jjkielce
Using the editor in version 2.1 I converted one of my GTS projects to GTS2
https://amazfitwatchfaces.com/gts/view/4826 and the user who downloaded the file reports a problem. It can install the watch face, the dial works fine, but if it tries to change the watch face on the clock, going back to W-Face won't work and needs to reinstall W-Face. I will be very grateful if someone checks this file on their GTS2 or if the designers check it in the editor. P.S. many thanks to SashaCX75 for creating this editor. efficient straight with great possibilities. Bravo
Posted: 13 Apr 2021, 09:28
by SashaCX75
jjkielce
You have a 1 pixel preview picture. Make it a normal size.
To do this, just click Refresh Preview in the editor. and in the dialog box, select No.
Posted: 13 Apr 2021, 14:40
by jjkielce
SashaCX75 wrote: 13 Apr 2021, 09:28
@jjkielce
thanks for the reaction. I've already done it. I hope this will solve the problems and we will gain experience. Best regards and good health.
Posted: 14 Apr 2021, 10:47
by Rjonet
the program does not work for me, it starts perfectly, I unzip the file.bin and nothing appears, without any errors. help me please.
Posted: 14 Apr 2021, 12:00
by SashaCX75
Rjonet
A folder with the bin file name should appear in the Watch_face folder. It should contain a log file. The bin file itself can also help figure it out.
Posted: 14 Apr 2021, 12:51
by Rjonet
Grazie
Posted: 14 Apr 2021, 12:53
by Rjonet
Grazie
Posted: 14 Apr 2021, 15:56
by SashaCX75
Rjonet
The casio_f91w_47mm_zip.bin file is not from GTR2 and therefore is not unpacked by the editor.
The file fr_b_lr_gtr2-114463-e11ed767fe.bin is normally unpacked by the editor. If you are not, then try to update the framework to version 4.5, move the folder with the editor to the root of the disk and try again.
Check the Watch_face folder to see if there is a folder with the watch face name and a log file in it.
Posted: 15 Apr 2021, 15:53
by yakface
@SashaCX75
The tools you released have been really amazing. You mentioned that some of the elements do not work with the converter script. Some of the more complex WF with animations dont translate well but I noticed that the battery information consistently does not transfer. Is there a way to get that to work?
Posted: 15 Apr 2021, 16:09
by SashaCX75
yakface
If the battery is displayed only in text, it works.
I suppose if one display mode is set for the battery, then it will work.
Posted: 15 Apr 2021, 16:54
by jjkielce
@jjkielce
the user confirmed that the shield is 100% functional. thanks. I will remember this lesson (it is not worth taking shortcuts and not saving the capacity of the watch here). Best regards and good health.
Posted: 21 Apr 2021, 05:45
by gengtrex
hi sasha.
i have tried to create T-rex Pro wf by your latest editor (GTS2 / GTR2 / Trex-pro).
everything looked perfect from beginning to packing.
but when uploaded from mobile to t-rex pro watch, it failed and just loaded the default wf.
can you give me some idea how i can fix this?
thanks a lot in advance.
Posted: 21 Apr 2021, 14:04
by tlausl
gengtrex wrote: 21 Apr 2021, 05:45
@SashaCX75
hi sasha.
Same here.
Posted: 21 Apr 2021, 16:15
by SashaCX75
gengtrex , tlausl
