- Administrador
Does not replace the clock face.
Same here. Some watch faces work, but a lot of them not. Last update of Amazfit (3.4.7) helps (a few more watch faces work) but still some others fail.
I guess I've found a workaround: do not load watch face from AmazFaces, but from the Files App. The process working for me is:
- Found the watch face in Safari.
- Download it (to Files / iCloud / Downloads folder).
- Open Files and select downloaded file.
- Select Share with, and send it to AmazTools.
- Install.
I've tried with some problematic watch faces and now all is ok.
I guess the problematic app is AmazFaces.
- Install.
- GIK-Team
- root
- Registrado em: 22 Mar 2018, 10:00
- Has thanked: 1164 times
- Been thanked: 279 times
- Contato:
We are already working on a new version of the AmazFaces, soon everything will work
Any idea on when the new version will be ready?GIK-Team escreveu: 01 Dez 2019, 14:11We are already working on a new version of the AmazFaces, soon everything will work![]()
- GIK-Team
- root
- Contato:
Our developers are already working on it. As soon as possible.
Started another post but I have the same problem. Tried everything, install MInfit instead of amazefit but doesn't work either. Hope there is a solution fast,loved the watchfaces from this apl
Monkey Face
- Registrado em: 02 Out 2019, 00:49
- Contato:
Same problem here, after latest update (which I installed Dec 1 2019). Although prior to this latest update, I was able to replace stock watch faces with User-developed from Amazfitwatchfaces , Clearly a software problem with the update. I look forward to a fix, as without ability to replace stock faces, this watch becomes of little use. I do love the watch (prior to this software problem), and it is my favorite, even preferred to the best of Samsung, Huawei, which I also, own.
Darksymphony
- Registrado em: 26 Nov 2019, 17:22
- Contato:
with the last update 1.2 I have the same problem . Whatever I put in the dial always goes back to the default watchface
- osmat
- Admin
- Registrado em: 22 Mar 2018, 10:09
- Has thanked: 35 times
- Been thanked: 73 times
- Contato:
I had this problem too.
I found it is important to rename your new watchface .bin file to the name of the old watchface in the folder.
This requires you to;
1: copy the name of the original watchface .bin file
2: delete the original watchface file
3: rename your new watchface .bin file to match the original file name
That way you will notice it does not download the original watchface file again.
It will start syncing the watchface immediately.
This even works with my GTR Lite, which I initially thought was not supported.
- osmat
- Admin
- Contato:
Quem está online
