Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
jeffrey38
Has thanked: 10 times
Been thanked: 12 times
Post by jeffrey38 »
lukbe
Been thanked: 8 times
Post by lukbe »
Here is version 5.1:
https://mega.nz/#!rEpxRYiJ!Cv7AAYr4rFvS ... taBUYuYGQs
News:
- English language is supported
-support for compressed bin file
gizmo2k4
Post by gizmo2k4 »
hi, i made a WF for me , but how i make the bin file ? can anyone help me ? when i click on pack bin it doesn´t do anything .
Louis_Cypher
Post by Louis_Cypher »
lukbe wrote: 29 Dec 2019, 09:03
News:
Just now that I was almost a Russian speaker?! Lol
+1 for instructions to compile .bin file.
gizmo2k4
Post by gizmo2k4 »
So how compile the bin file? Thx
Lordalpine
Been thanked: 35 times
Post by Lordalpine »
In Version: 5.1 // How to set Language to English
Go to Hactponkn [ Option ]
Language Selection is there
The app will restart^^ Magic^^ 90% of the App is translated
gizmo2k4
Post by gizmo2k4 »
calom
Post by calom »
I cant put to work this tool... when I try to open a bin file just open a DOS window but close and nothing appear.
This tool can open an existent bin file face and then edit?
Any help please?
Volker Liebzeit
Post by Volker Liebzeit »
jeffrey38 wrote: 22 Dec 2019, 15:30
Can you please tell me where to find it? Still can't unpack anything with weather.
Lordalpine
Volker Liebzeit wrote: 01 Jan 2020, 19:23
The way to avoid Unpack Problem is to retrieve "Fix array Branches"
With Loly Dev GTR, you can Unpack Bin with Weather... but when you will want to Unpack Bin with Weather and Extra Analogic Hand, You will have the same problem
I Had this problem, let me explain, I can Pack and unpack with the Python tool I had : All bin + weather.
Then I wanted to Unpack An Hikashi Watchface with Extra Analogic Hand [ Because I wanted to Know How it was done reading the Json file ] and I Can't Unpack It. The Tools says "Done" but I had only a log File with "an error of function not supported"
So I move to dpeddi Branch " Fix Array" To Pack and Unpack : Bin / Json + Weather + Extra Analogic Hand
Setup Python Tool environment
viewtopic.php?f=38&t=1110
SashaCX75 Gui Tool No Python Version
Horatius80
Post by Horatius80 »
Amazfit_RainbowCircle.zip
Compressed bin file:
(149.7 KiB) Downloaded 1490 times
Has thanked: 419 times
Been thanked: 2109 times
(607.67 KiB) Downloaded 2156 times
Lordalpine
asoo wrote: 07 Jan 2020, 02:54
Lordalpine wrote: 08 Jan 2020, 10:11
( Thank SashaCX75 )
Ekohero
Post by Ekohero »
have the problem with
I cant extract the bin.
Matth78
Post by Matth78 »
Does compile work? I failed to do it with Windows without python. I don't understand what is wrong since it seems so simple! 😓
Edit :
For those who may have the same problem, mine was coming from no transparency on some image.
After adding transparency I have been able to pack. (But produced bin does not work on my watch T_T)
Ekohero
Post by Ekohero »
no compile:
bin to -> open file directory does not work
so I cant edit this watchfaces
I wanted to see how the circles for calories and temperatur are done
GTR_WatchFace editor for Windows by SashaCX75
Version 5.2 full
The program is available for download now.
http://4pda.ru/forum/index.php?showtopi ... ry92847810
Обновил Графический редактор циферблатов
Добавлена поддержка набора иконок (иконки и набор координаты к ним) для прогресса шагов и батареи.
Добавлена возможность обрезки предпросмотра по форме экрана.
Исправлены ошибки в английской версии.
Google translate
Updated Graphical Dial Editor
Thank SashaCX75
kampanita
Has thanked: 8 times
Been thanked: 7 times
Post by kampanita »
asoo wrote: 13 Jan 2020, 18:22
Version 5.2 full
Google translate
Thank SashaCX75
I can not download from 4pda.ru , not registered at that site....I tried to but don't understand russian and google translate didn't help also.
Could you upload 5.2 version to somewhere else ( mega / drive ... ) ?
kampanita wrote: 14 Jan 2020, 08:17
I'm not sure if 4pda allows copying this file for distribution outside of the 4pda in public.
To conclude, I sent my link that I uploaded for you in PM.
Please SEE your Private message
Horatius80
[mention]asoo[/mention] please, if it is possibble, share the link with me also ... many many thx
Horatius80 wrote: 14 Jan 2020, 10:44
@asoo please, if it is possibble, share the link with me also ... many many thx
Next time, who wants my link?
Please PM to me
Do not post request
Thank
If you want to improve the translation or add a translation into other languages, write in PM.
Kastelic
Post by Kastelic »
many many thx
Starlince
Post by Starlince »
hola a todos, perdón por mi petición, pero es que me he bajado el programa watchfaces tools en inglés pero no se como funciona, se que es mucho pedir, pero alguien me podría decir, indicar o remitir a unas instrucciones para un novato?? Muchas gracias de antemano y perdón por las molestias.
