- Amministratore
HELP: About "Animation" code Mi Band 5..
Hi Jackall Digital and all members.
I´m new to this forum and i´m testing this animation code:
"Other": {
"Animation": [
"AnimationImages": {
"X": 0,
"Y": 124,
"ImageIndex": 66,
"ImagesCount": 12
"Speed": 1,
"RepeatCount": 10,
"UnknownTF4": 1
I´m using 12 images as you can see NOT to animate them, just want to scroll them tooth by tooth, so i used "Speed": 1 because like this i´m able to scroll tooth by tooth, one by one ... the problem is when Mi Band 5 screen goes off the animation goes back to "Imageindex": 66, and i want it to stay on image i choose..
What changes should i make in the code so i can be able to stay on the image i choose till next time screen lights on and then choose another one if i want??
Hope you understand and help me.
Cheers
DuRoi
"Other": {
"Animation": [
"X": 0,
"Y": 124,
"ImageIndex": 66,
"ImagesCount": 12
"Speed": 1,
"RepeatCount": 10,
"UnknownTF4": 1
Cheers
DuRoi
- Jackall Digital
- Has thanked: 1 time
- Been thanked: 14 times
- Contatta:
Hey Duroi,
I don't know if mi band 5 works differently than mi band 4. In mi band 4 the animation is just that, animation and it always starts from the start whenever you turn on the band. I would imagine mi band 5 works in the same way and as such what you want is not possible. Unless you saw a watchface that does what you want.
Cheers
Jackall Digital
Cheers
Jackall Digital
Hey Jackall,
Thanks for fast reply
Yes its the same in mi Band 5, and i know the code point to start the picture number you put there.
I was hoping that with a little more code it would be possible... Not bad like this but if i could choose the image it would be better.
Thanks anyway.
Thanks anyway.
Thanks MiDesign,
Do you know a way to archive my goal?
I have 12 images... and i want to choose one of them and stay with it till next time i choose another .. and so on...
I really need that to my daughter, everyday she`s asking me that ... it´s insane lol
Visitano il forum: Nessuno e 22 ospiti
