Been thanked: 1029 times
Messaggio da SashaCX75 »
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Fringo
Messaggio da Fringo »
SashaCX75 ha scritto: 05 mar 2021, 16:35
Rcappa ha scritto: 05 mar 2021, 02:44
Thanks but its there any way to login into site in English. I can't decode the Catcha in Russian
A little later, when the translation is corrected, I post the editor on this forum.
It works on ZEPP E Circle too! Thank you very much! I look forward to improved version :)
(I'd got resized images and coordinates from tool for GTR47, using converting function)
ajeto
Messaggio da ajeto »
I'm getting errors with main.py when decompiling
https://amazfitwatchfaces.com/gtr/view/12898
after decompressing
Codice: Seleziona tutto
raise IndexError(f"Parameter {parameterId} isn't supported for {currentType}")
IndexError: Parameter 2 isn't supported for <class 'watchFaceParser.elements.gtr2.basicElements.circleProgress.CircleProgress'>
Has thanked: 414 times
Been thanked: 2073 times
Messaggio da asoo »
ajeto ha scritto: 07 mar 2021, 08:46
after decompressing
viewtopic.php?p=8393#p8393
Ultima modifica di asoo il 07 mar 2021, 11:37, modificato 2 volte in totale.
rubiales41
Messaggio da rubiales41 »
hello, how much can the sphere weigh in megabytes, at most ?, for GTR 2?
mehrdadrahimian
Messaggio da mehrdadrahimian »
SashaCX75 ha scritto: 07 mar 2021, 10:41
AmazFit WatchFace editor 2 with support for GTR 2, GTS 2[/color][/size]
Hi. Please also support the Bip u & Bip U Pro models. They are not supported in any of the Amazfit software. And it is not possible for them to be unpacked BIN file. Thank you for your efforts
lucaslee
Messaggio da lucaslee »
whether there will be a Polish version for this application?
r33ck
Messaggio da r33ck »
Horatius80 ha scritto: 17 feb 2021, 13:57
fkicin ha scritto: 16 feb 2021, 21:04
It's my first post so Hi all.
Sasha what is the official (or other) soft to edit watchfaces for GTR2? i can see custom wf here but i can't find any tool to creat such custom image :(
Here is "tutorial" video how to obtain access to Huami official develop tool for watchface creation. It is only on-line tool
(I see a similar question but I haven't found an answer, please and thank-you)
Hi All,
Many thanks to dimas for the youtube video on Huami registration. I'm in process.
Question: How to download an internal watchface? To start I'd like to add DND and bluetooth icons to the Multifunction WF in Zepp but can only find it in Zepp. GTR2, Pixel 5 phone and it isn't in any folder I can access.
Rick
gengtrex
Messaggio da gengtrex »
Your T-rex editor is so awesome.
Is watchface editor for T-rex Pro now available.
Thanks a lot in advance.
gengtrex
My editor is not designed to work with T-Rex Pro watch faces. The site has one dial made for this model. Ask its author what tools he made it with.
gengtrex
SashaCX75 ha scritto: 27 mar 2021, 18:41
@gengtrex
I see. Anyway, thank you again for the editor and lots of advices. :)
yakface
Messaggio da yakface »
Im also very interested in what application was used to create the TREX PRO watch faces and if there is a way to convert existing TREX watch faces to be TREX PRO compatible.
Horatius80
Messaggio da Horatius80 »
SashaCX75 in my humble opinion, the principle of watchfaces for T-REX PRO will be the same as for GTR2 (support for widgets etc.), only it will be necessary to adjust the resolution to 360x360.
So Your Watchface editor 2 will be applicable. Correct me if I'm wrong
Horatius80 ha scritto: 04 apr 2021, 18:16
@SashaCX75 in my humble opinion, the principle of watchfaces for T-REX PRO will be the same as for GTR2 (support for widgets etc.), only it will be necessary to adjust the resolution to 360x360.
Yes, the principle is the same. Probably the next version of the editor will support T-REX PRO.
We need T-REX PRO owners ready to test this update.
spidercrab
Has thanked: 27 times
Messaggio da spidercrab »
SashaCX75 ha scritto: 05 apr 2021, 16:09
Excellent. I will certainly be testing. Standing by.
Ultima modifica di spidercrab il 08 apr 2021, 15:39, modificato 1 volta in totale.
Thinkpad
Messaggio da Thinkpad »
I'm ready to test this update.
andijbellinger
Messaggio da andijbellinger »
I've just got a t-rex pro and would be happy to test.
Turtl3sh3ll
Messaggio da Turtl3sh3ll »
T Rex Pro User Here, ready to test & Learn watchface creation.
Is the executable hosted on a stable platform yet? Suurceforge / etc?
pory
Messaggio da pory »
Rady to test!
CASIONFAN2021
Messaggio da CASIONFAN2021 »
Thanks to sasha for this amazing product. I would ask that there be an update to the watch face editor 2 for the t rex pro that allows the entries for moon phase and the sunrise sunset that is present on the stock watch faces. Is that possible?
maortrol
Messaggio da maortrol »
CASIONFAN2021 ha scritto: 17 mag 2021, 07:30
Why don't you ask that in the WatchFace editor 2 thread?
viewtopic.php?f=29&t=1888
gengtrex
with the t-rex editor.
when i load .bin to notify app, it always shows 'unable to retrieve preview image'.
how can i fix this and make it show?
thanks in advance.
CASIONFAN2021
Not sure. I've had a few faces that show a preview and others that don't
gengtrex
I didn't quite understand what kind of error occurs. Send a window with an error and describe in detail the actions in which the error occurs.
gengtrex
SashaCX75 ha scritto: 24 mag 2021, 15:31
@gengtrex
it shows as the pic below, after i choose the .bin in notify app. anyway the uploading is successful everytime.
Torna a “Watchfaces tools”
