Download/sync error
Download/sync error
I am able to download/load faces but when i replace an existing one it works . When i try the other option it just constantly tries to sync and fails.
Is it possible to install an older version of the app that used to work?
- Stas
- Has thanked: 4 times
- Been thanked: 34 times
What is your watch?
Ivtevet wrote: 19 Oct 2020, 05:41I am able to download/load faces but when i replace an existing one it works . When i try the other option it just constantly tries to sync and fails.
Same problem, but i can't use the replacement nor direct installation.
T-Rex
T-Rex
Oventuravictor
deepblue2000
- Has thanked: 5 times
Collins1969
