MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Messaggio da lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Ultima modifica di lvpokka il 02 ago 2020, 19:41, modificato 24 volte in totale.
abcd840322
Messaggio da abcd840322 »
Nestdot ha scritto: 09 ott 2020, 15:45
I finished making my watch face with this tool, but when I want to compile it it says it is greater than 615kb, it says it is 1093 kb, but in reality is just 511kb, the problem seems to be a gif included in the watchface (it has 30 frames) and when I set it to 10, it can compile it, I'm not really sure why though, here's the log error part, I can't include the pastebin link :/
Set "UsePaletteMode" value="1" in file WatchFace.exe.config
pacow
Messaggio da pacow »
lvpokka ha scritto: 01 ott 2020, 22:05
guaynaa ha scritto: 01 ott 2020, 21:23
It works great but I think this has a virus or bug, maybe unintentional.
Aside from windows defender alerts, after using this software my browser started to randomly freeze
Is anyone else experiencing the same?
Yes, read this topic
Hi. ;-D New here. I've got the same problem. No threats are found after scanning my disk, but I'm not going any further until someone says it's okay to proceed. "Read this topic" isn't very helpful with 22 pages, you know. ;-)
lvpokka
Not a virus, or you can just do not user Viewer, main wf tool app is not classified as virus.
eugenb
Messaggio da eugenb »
Thanks for this tool, I had great fun with it creating faces for my Amazfit Bip. I have a Mi Band 5 now and I'd like to create some more. I prefer the ones that hide all other info except for the clock when in locked mode. That saves some battery in the "lift wrist to view info" mode or if you just want to know the time and makes the band cooler. :D
It's really simple to do, you just need to replace the lock icon with a black background that has a cut where the clock is. The problem is that, no matter what I try, there are elements on the screen that can't be hidden in this way because they are shown above. I'm not very good at this but I think it's because of the order in which different elements are activated.
Is there a way to make the lock icon somehow activate last?
abcd840322
The temperature would disappear sometimes on the Mi band 5.
pacow
lvpokka ha scritto: 14 ott 2020, 15:52
Thanks for your answer Ivpokka, and thank you for creating and sharing the tool. I'm going to use it. I hope to have great fun creating WFs.
By the way, my error. :oops: I was having the virus warning with version 2.1.6 only, while I was supposed to use 1.4.2 (I have a Mi Band 4). :lol:
dwqdwq
Messaggio da dwqdwq »
www.virustotal.com/gui/file/9ed8276cc55 ... /detection
mi band 5 wf tool
SHA1
47b5529c9c09bf1189ff8274178e755818ee0849
Windows 10 detected as malware or the blue warning screen came up. After running nothing happend. Could anybody please post a screenshot, how the tool looks like?
Is there a hash to check the exe checksum?
https://imgur.com/LBBGagB
urieleugenio
Been thanked: 7 times
Messaggio da urieleugenio »
Just click and drag the BIN file to unpack (or the JSON file to pack) over the tool (EXE file).
Insular
Messaggio da Insular »
Why it acuses a trojan horse on the latest version of this editor?
trojan horse: Spursint.F!cl found by windows defender
arthurking521
Has thanked: 7 times
Messaggio da arthurking521 »
Insular ha scritto: 22 ott 2020, 19:20
did u used the old version?if it is not ok also ,the problem is ur windows defender,which doesnot like it :D
rahmanjunior
Messaggio da rahmanjunior »
I'm trying to modify a PipBoy watchface for the Mi Band 5, all I do is change the position on day and month so it goes DD. MM instead of MM. DD but when I compile the modified JSON I get this error:
"Fatal|[ERROR] Watchface is greater than 615kb, it will not be accepted by Mi Band 5, please reduce size! Current size:1015kb."
But even if I don't edit the JSON I still get this error, could someone please help me?
EnesTR
Messaggio da EnesTR »
MiBandWFTool_2.1.6.zip file, and it looks like it's a trojan virus.
abcd840322
rahmanjunior ha scritto: 27 ott 2020, 15:11
Please read the topic. A lot of people have mentioned the same question and its has been answered for several times already......
rahmanjunior
abcd840322 ha scritto: 28 ott 2020, 07:57
Thanks so much, it worked =)
hyperaesthetic
Messaggio da hyperaesthetic »
Hello!
I downloaded mibandwftool v. 2.1.6. When I click and drag a wf bin file over the WatchFace.exe, I get forbidden icon, and the bin file doesn't get unpacked. I am a bit frustrated that I don't even get started. Any pointer will be appreciated.
Thank you!
arthurking521
hyperaesthetic ha scritto: 15 nov 2020, 04:39
Hello!
Thank you!
what is the error info ?
hyperaesthetic
Hello!
Thank for the reply.
The error info is... nothing happens. When I click , drag the bin file, which is packed wf file, onto the WatchFace.exe, nothing happens.
Hyper
arthurking521 ha scritto: 20 nov 2020, 09:16
Hello!
Thank you!
abcd840322
Hello!
Thank you!
Did you unzip the file before dragging the bin? Or you can try to download it again?
dheerajmalviya007
Messaggio da dheerajmalviya007 »
Whenever i download mi band 5 tool, my Windows defender deletes it automatically idk why, defender says it has virus...
Any solution?
hyperaesthetic
Hello!
Well, I unzipped the WF.exe, but not the bin file.
It seems fairly straightforward, but it doesn't work for me. I tried downloading it to a different computer, but I have the same problem.
abcd840322 ha scritto: 23 nov 2020, 06:13
Hello!
Thank you!
Tech72
Messaggio da Tech72 »
What code for json do I use for wind and UV?
Toccea
Messaggio da Toccea »
Hello. I have my band 5, found an animated watch face, but wanted to add my logo. i was able to use the latest version to open it, even added the logo too, but wasnt able to make it a .Bin file again. i even tried making it a bin file without touvhing the watch face(reinstalled) and it wasnt working on that waz either. how am i able to fix it?
Malombrado
Messaggio da Malombrado »
Always got this error trying to upack a Miband 5 bin
Codice: Seleziona tutto
Trace|11.1.4 'UnknownTF4': 0
Debug|Generating previews...
Error|System.Runtime.InteropServices.ExternalException (0x80004005): Erro genérico de GDI+.
   em System.Drawing.Image.Save(String filename, ImageCodecInfo encoder, EncoderParameters encoderParams)
   em FBdrVENTOSQNAwAAQU.BV9w4uUq25cVnqdLQO.SP7WnWknn(List`1  , List`1  , String  , String  , Int32  )
   em FBdrVENTOSQNAwAAQU.BV9w4uUq25cVnqdLQO.yxuUbFugF(String  )
Debug|Exporting resources to 'C:\Users\marco\Desktop\miband\among_us_marcosdecamp_-379563-f98053b469'
Debug|Extracting C:\Users\marco\Desktop\miband\among_us_marcosdecamp_-379563-f98053b469\0000.png...
shirumitsu
Messaggio da shirumitsu »
what size max the .bin mi band 5 suport?
Gads
Messaggio da Gads »
How i can put a GIF in the background? ... No in the background but behind hour, date and etc... Behind the other stuffs. Its possible? Thanks
Torna a “Watchfaces tools”
