Share your today's watchface / watchface making process [Mi Band]
urieleugenio
Been thanked: 7 times
Post by urieleugenio »
Testament wrote: 02 Sep 2020, 06:12
How to change the .bin size or rearrange it ?
I'm not sure I know what you mean.
You can keep the BIN file size down by keeping down the size of the images that make the BIN file (low number of images and / or small size of images), if that's your question.
Testament
Post by Testament »
urieleugenio wrote: 02 Sep 2020, 10:58
Yes , I know that I am unable to decrease the size and length of the image , it turns too small and looks very bad in my band . Can you please help ?
urieleugenio
Testament wrote: 02 Sep 2020, 11:05
I've had watch faces with 100 images, and I was still far from the BIN size limit, are you using an animation with big images and lots of frames?
Try to reuse images too, using the same numbers for hours tens, hours ones, minutes tens and minutes ones.
Use images with a background (no transparency) for smaller size, or cut them to size.
Lastly, you may try the Palette mode on Ivpokka's tool, it's meant to readuce BIN file size (but it can lower image quality).
Testament
Post by Testament »
urieleugenio wrote: 02 Sep 2020, 12:00
So I should check the dimensions .
Jackall Digital
Been thanked: 14 times
Post by Jackall Digital »
You can optimise images, lower the size and keep the quality, if they aren't by using PNGgauntlet (free software), I'm not saying that it will help but it might. I also advise you to check my videos as they will save you time - like trying to make the perfect design from the start only to find out that it doesn't work like you want it to after you code it.
Testament
Post by Testament »
Jackall Digital wrote: 02 Sep 2020, 21:54
Hi friend , can you please give me the link to your videos . Thanks
Jackall Digital
Testament wrote: 03 Sep 2020, 02:06
There you go. And I'm currently making a video that'll focus on coding the progress bar
https://www.youtube.com/watch?v=AATx7YB ... HST_ZN7moS
Testament
Post by Testament »
Jackall Digital wrote: 03 Sep 2020, 12:56
Thanks , will it contain all the coding processes to be added and to correct them
Testament
Post by Testament »
How can I get any GIF from the watchface that I made ? Does it makes it by itself or we have to make our own ?
Jackall Digital
The .gif and .png of the watch face is made automatically when you compile the .json file.
edit: the steps progress video is also up. I didn't make a watch face specifically for this case, but I have shown what you need to do to implement it - and there's a bonus that you can use in steps progress that not many people know about! https://youtu.be/QSUVXfx0r7o
Testament
Post by Testament »
Jackall Digital wrote: 06 Sep 2020, 07:39
Thanks for the video and the information .
sdurio416
Post by sdurio416 »
francesseSA wrote: 01 Sep 2020, 02:54
Can we use other tools then using Photoshop or other similar programs ?
I use Inkscape to create mine. I create a raw svg file then export the pngs I need.
laurenince525
Post by laurenince525 »
urieleugenio wrote: 29 Aug 2020, 10:52
Right now I'm using this one (simplified, en ddmm version): https://amazfitwatchfaces.com/mi-band-5/view/373 https://www.worktime.com/employee-monitoring
This other one was my go-to watch face until recently, and I made different versions with a more or less complex dial: https://amazfitwatchfaces.com/mi-band-5/view/323
looks cool! :) here is mine at the moment
https://amazfitwatchfaces.com/mi-band-5/view/2671
Post by 1337 »
Watchface with the Kali NetHunter logo.
https://amazfitwatchfaces.com/mi-band-4/view/20217
Post by 1337 »
Watchface 2.0 with the Kali NetHunter logo.
https://amazfitwatchfaces.com/mi-band-4/view/20224
