MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Messaggio da lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Ultima modifica di lvpokka il 02 ago 2020, 19:41, modificato 24 volte in totale.
BatataNoFrita
Messaggio da BatataNoFrita »
Hello, really like the work being done here,
May I join the beta? Thanks
Ybruz
Messaggio da Ybruz »
Looks great, can I join the beta please? I'd love to create some watch faces for my new mi band 5
lvpokka
Mi band 5 tool released from beta. Link added to topic :D
urieleugenio
Been thanked: 7 times
Messaggio da urieleugenio »
lvpokka ha scritto: 31 lug 2020, 21:26
That's awesome, I'll take a look during this weekend!
elhombremaquina
Messaggio da elhombremaquina »
Thank you!!!
Chapi666
Messaggio da Chapi666 »
My antivirus software don't like "WFPreview.exe".
It says that it's a trojan. It detects it as "HEUR:Trojan.Win32.Generic".
Is it a false positive ?
lvpokka
Chapi666 ha scritto: 01 ago 2020, 16:48
Try https://www.virustotal.com/gui/home )) have no idea about it, its simple and clean program. you can remove it if you don`t trust it, it actually do nothing important)
Yife Playte
Messaggio da Yife Playte »
It's great to see the updated tools. but hey, could you please give me a sample json for band 5 which have all elements included? That'll be helpful.
Goublin
Messaggio da Goublin »
Hello everyone, I have tried to decompress and re-compress the same .bin without modifying anything with the Mi Band 5 WF Tool version
v2.1.4 and it gives me error, don't create the .bin
Why is this happening?
I have tried modifying the .bin and unmodified and it gives me the same error.
Fatal|[ERROR] Watchface is greater than 615kb, it will not be accepted by Mi Band 5, please reduce size! Current size:866kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 615kb, it will not be accepted by Mi Band 5, please reduce size! Current size:866kb.
en AKJgAM2UjJeDpEamRk.hJSbbkjeCJyTvnyiI1.amGLIDL4l(String )
en AKJgAM2UjJeDpEamRk.hJSbbkjeCJyTvnyiI1.SVSXpRmi8(String[] )
Thanks in advance.
lvpokka
Read readme... there is palette and raw mode watchface compressor
Goublin
lvpokka ha scritto: 03 ago 2020, 19:17
how do you do that? Sorry, it's the first time I do this
lvpokka
Goublin ha scritto: 04 ago 2020, 09:28
Find mi band 4 manuals) i will not explain you all process... i think watchfaces not for you bro, sorry :(
Goublin
lvpokka ha scritto: 04 ago 2020, 09:49
Do you know of any link in any manual please?
Adore_able
Been thanked: 6 times
Messaggio da Adore_able »
Awesome but can you please tell me how to unpack and pack a .bin file . Although I read this thread many times but unable to pack , unpack it .
So can anyone please help me in this situation ???
Inspiring great affection and delight
urieleugenio
Adore_able ha scritto: 04 ago 2020, 16:18
To unpack you need to click on the BIN file, drag it, and drop it over WatchFace.exe. You can also right-click over the BIN file and select 'open with', and then manually select WatchFace.exe (you'll need to look for it in the folder you saved it).
This will unpack the BIN file into a folder (in the same location where the BIN file is), with the images and a JSON file.
To pack (after making the changes you wanted), you need to drop / open the JSON file with WatchFace.exe.
This will pack the JSON + images into a new BIN file. It will also create dynamic and static previews of the WF.
mc200x
Messaggio da mc200x »
How to run 2.4.1 script on linux (mono) or mac ?
getting this error System.InvalidProgramException: Invalid IL code in VxevgnPEK1LvCeXIub.WhqXyRnXCUjjFRCmTS:HMXFhiOdN (string[]): IL_0185: pop on mono
Adore_able
urieleugenio ha scritto: 04 ago 2020, 20:26
Thank you very much , will let you know when done .
Thanks for your help
Pebbler
Messaggio da Pebbler »
Hi, have been using it since Mi Band 4, great tool!
Found some inconsistency between generated preview and real device display:
In PreviewStatesV2.1.4.json, when "Bluetooth" is set to false, Status.Bluetooth.ImageIndexOn is shown, and ImageIndexOff is shown when Bluetooth is true. I find it counterintuitive. WF is working great on device though, ImageIndexOn is shown when bluetooth is connected.
Also if watchface has 10 pics for BatteryIcon, the first one (which indicates lowest battery level, often in red color) is shown in generated preview if BatteryLevel is set to 9 or lower, whereas on real device, this red battery icon kicks in as soon as battery drops to 15%
Another issue is, Mi Band 5 can store up to 3 different custom WFs on device, and you can choose between them on device without touching your phone. The band seems to detect same WF based on some ID written in .bin file, but all WFs generated by MiBandWFTool seems to be using the same ID. This causes on device old custom WF get overwritten when another custom WF is uploaded even if there is empty slot on band. In other words, band can store only one WF packed by this tool at any time.
Using another packer called mi5wf_tool_1.0.2, I can upload three custom WFs to band at the same time, but that tool have compatibility issues on packing/unpacking many WFs.
All WFs packed by MiBandWFTool, when unpacked by mi5wf_tool_1.0.2, seems to have this string "\u0001\u0011\r=\u0000=\u0000\"'\u0000\u0000?\u0005\u0000" in header. And I see different strings when unpacking official WFs. Not sure if this is the ID, don't know what it means, just hope this helps.
gsomgsom
Messaggio da gsomgsom »
Pebbler ha scritto: 05 ago 2020, 09:36
Hi! Thanks for your research!
Where did you find another tool? Can you please share it (PM)?
I'm also doing researches in header format.
lvpokka
BIg thx for research, but for now header will stay the same because of its hard to generate new header for each one, and Chinese tool is just saving previous one, if you will take any wf from here it will reuse same header and the problem will appear again)
Working on that, hope gsomgsom will have luck to reverse header.
btw. Chinese tool is awful and can handle only 40% of new elements...
Adore_able
How to convert a dial into a GIF ?
I tried using your creator but it's still impossible to make it animated
Please tell me how to make it a GIF?
lvpokka
Adore_able ha scritto: 05 ago 2020, 16:29
Could you please find this answers by your self by unpacking watchaces with animations and check json of it?
Or create you question in different thread. (ex. viewforum.php?f=14) OR (ex. viewforum.php?f=25)
This forum is NOT for tutorials, its for BUGS of this tool...
franluciani
Has thanked: 9 times
Messaggio da franluciani »
I found that you can only draw with 5 points or less the pointers of analog dials. Also the seconds of analog clock are not working yet.
In status simplified, i think that some of unknown values are from alignment of status icons.
I hope this help to developers to keep improve the tool. Anyway excelent job with the tool
lvpokka
franluciani ha scritto: 06 ago 2020, 20:08
Yeap but what is the point of alignment if you can set x and y :D i will make more testing when my band will eventually arrived... :roll:
franluciani
lvpokka ha scritto: 06 ago 2020, 22:41
Hahaha i mean you can alignment bluethoot, do not disturbe and lock icons, because some elements can be on and others off. For example: bluetooth it's on, lock on and do not disturbe off, you could alignment this two icons at center, for example
Torna a “Watchfaces tools”
Visitano il forum: Nessuno e 26 ospiti
