Been thanked: 1029 times
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
panuj
Post by panuj »
Hi! I hava a problem with day/night temperature on t-rex watchface.
I would want to add into watchface all weather info: icon, current, night and day temperature. Everything works nicely when creating the watchface, but when installed, only it shows only current weather - day/night temperatures are blanc.... I've read all the previous conversation about the day/nigh temperature, tried all the tricks and nothing seems to work. I have double checked that all the needed info and files are there, error files etc...
Anyone else has the same problem? Any idea how to fix this?
I haven't found any t-rex watchface with all the info so I could test that...
muhvs
Post by muhvs »
We're sorry. You can't access this item because it is in violation of our Terms of Service.
I keep getting this when i Try to Download your Editor Tool ;(
Kraudi
Post by Kraudi »
muhvs wrote: 02 Jul 2020, 10:29
Same here.
kampanita
Has thanked: 8 times
Been thanked: 7 times
Post by kampanita »
[mention]SashaCX75[/mention]
I'm using the 8.1 version of your tool with this one https://amazfitwatchfaces.com/gtr/view/6815
i'm getting an error....could you help me ? I was unable to find 8.2 version, is not at google drive and i can not log into 4pda.ru
Thank you in advance.
Updated download links.
[mention]kampanita[/mention]
Checked this dial. I normally unpacked it. Try resetting the program or downloading the latest version.
panuj wrote: 01 Jul 2020, 08:38
Day / night temperature is only displayed if the current temperature cannot be displayed.
panuj
Post by panuj »
Ok, thanks. I used to have Amazfit Bip -and created watchfaces which showed all of them at the same time. Shame that t-Rex can’t do the same.
wing0826
Has thanked: 9 times
Post by wing0826 »
I try many watchface for T-rex
they all dont show AM/PM on my watch , it's no photo or incorrect
can someone try this?
another question~
can I show the two digit year?
thanks!~
[mention]wing0826[/mention]
The format for displaying the time on the watch depends on the settings of the phone. For the 12 h format to work. must be enabled in phone settings. (Settings-System-Date and Time-Disable 24-hour format.)
wing0826
Post by wing0826 »
thanks [mention]SashaCX75[/mention]
after trying, i got this
if I want use the AM/PM image, I must set the two AM & two PM image,
like this one, but I dont know why :shock:
https://amazfitwatchfaces.com/t-rex/view/908
Not. One AM image and one PM image are enough. The dials seem to support two images for AM / PM (like for two languages), but this is not implemented in the program.
wing0826
Post by wing0826 »
Oh okay, now I get it!
thanks @SashaCX75 making this program!~
madmax
Post by madmax »
Hi, i have a problem with the temperature indicator if i don't use before amazfit with my iPhone there is nothing on screen: why? thank you
spidercrab
Has thanked: 27 times
Post by spidercrab »
@SashaCX75
I have a strange problem when using the Activity - Pulse - Pulse Segments.
I am using 123, 140 for 6 images, and each image is 2Kb. The Preview works perfectly when testing inside the Tool. All 27 images now total to about 120Kb.
Before I added this pulse segment feature, my zipped packed bin was 147k with 108Kb of images.
However, I now get a warning when creating a new Packed Zipped bin to say the Packed size is over 1.5Mb, and it may not work. This size seems huge in relation to the images used.
So my expectation was that the worst increase in Packed Bin size would be 6 x 2Kb = 12Kb of added images.
I have a 0001 image which is a duplicate of 0000.png. Can I create a blank round image for the 0001.png to save space here? Or is there something else I need to do.
Edit - I am wondering if an image is being created for every pulse, i.e. 200 approx image = 2k x 200 = 400kb ?
[mention]madmax[/mention]
Where do you think the weather data comes from? Amazfit downloads data from the weather server and transfers it to the watch. It often happens that amazfit cannot receive data on current weather and then it is not displayed on the clock either.
[mention]spidercrab[/mention]
No need to consider the size of the pictures in kb. Read the first post to understand what the size of the bin file depends on.
The size of the preview image is usually smaller than the background and if necessary it can be reduced to 1px.
madmax
Post by madmax »
ok but the thing I don't understand is that the weather icon is always there while the number disappears completely. have a nice day
my fault set-up on the wrong cell phone sorry
madmax
Post by madmax »
your program is very very very good!!! thank you so much for it
Horatius80
Post by Horatius80 »
spidercrab wrote: 07 Jul 2020, 12:04
@SashaCX75
1.) Size (MiB) of .bin depends on the size of the image in pixel and not in KiB
2.) The preview image 0001.png does not need to be defined (you leave a blank space for the imageindex in the editor). Then you can continue numbering other pictures from 0001.png etc.
enerwate
Post by enerwate »
panuj wrote: 03 Jul 2020, 08:07
I confirm that. The current and max min temperature does not work in GTR at the same time. I also tried various tricks with json and nothing.
pity.
leonlee99999
Post by leonlee99999 »
Thank you so much Need Try It
Version 8.3
Bugs fixed.
kyle
Post by kyle »
SashaCX75 wrote: 17 Jul 2020, 18:32
Version 8.3
Bugs fixed.
I want to translate to Chinese manual
如有需要可联系!
muskatim
Post by muskatim »
I downloaded the program. I changed the png images after loading the watch face. Could you please write the instructions for use?
muskatim
Post by muskatim »
