- Адміністратор
question watch face 47mm to 42mm
Модератори: Internal error, Watchmens
rescoffi45
- З нами з: 14 вересня 2019, 10:31
- Контактна інформація:
hello
I am new and I wonder about watchfaces
47mm faces are they compatible with 42mm or should they be modified?
how to convert 47mm faces to 42mm?
Is there a simple way to quickly edit the files?
thank you
thank you
I am also curious about this, have you tried installing a 47mm on the 42mm ?
And did you find a way to resize them if uncompatible ?
Blackbeagle
- З нами з: 15 грудня 2019, 01:37
We need a solid reply from the developer. So far I've tried numerous times. Either it errors out or it reverts back to the stock two faces. Can the developer answer? There are a lot better faces on 47mm than the 42mm.
I have the same problem. ¿Is possible convert 47mm faces to 42mm?
kampanita
- З нами з: 25 жовтня 2019, 06:15
- Has thanked: 8 times
- Been thanked: 7 times
Said a lot of times ...... don't you use "search" tool of this forum ?minusero писав: 01 лютого 2020, 11:26I have the same problem. ¿Is possible convert 47mm faces to 42mm?
For converting 47mm to 42mm. take the bin ( it must be uncompressed first with RESUNPACKER.exe ) , then put it into a zip file and upload to
Код: Виділити все
https://wakeup.aliennation.lv/amazfit/Хто зараз онлайн
