- Amministratore
Change vibration level?
pepedom
manelto
Creo que no es posible, pero sí puedes cambiar el estilo de vibración: en llamadas entrantes, en recordatorios, en alarmas, en alertas de aplicaciones y en alertas de actividad existe un enlace con el texto vibración (en algunos casos con un icono). Normalmente está en predeterminado pero puedes cambiar el patrón de vibración (hacerlo más continuo, con distintos ritmos,...) para detectar mejor los avisos.
I think it is not possible, but you can change the vibration style: in incoming calls, in reminders, in alarms, in application alerts and in activity alerts there is a link to the vibration text (in some cases with an icon). Normally it is in default but you can change the vibration pattern (make it more continuous, with different rhythms, ...) to better detect the warnings.
pepedom
For me it have a high vibration level, even changing vibration pattern I not able to get more quiet notifications.
Gracias por tu post en español, pero creo que hay que dar la información para todo todos la puedan entender.
peaceweapon
- Contatta:
If you set a very short vibration time (in the Notify and Fitness for Amazfit App you can write down the time in ms) it will be very soft and short.
Go to the Top row "settings" menu (the one with the sliders like in a music mix table) and then choose Tools in the second row.
Amazfit settings --> Default Vibrations vibration --> Add new Vibration
If you add 50ms vibration, you'll feel just a small vibration.
You can make it shorter, like 30ms, shorter than that you might not even feel it.
Then you can go to notifications menu (the one with a mail letter) and change the initial ou end vibrations in a customized fashion for each app, also using vibration and pause times to change them.
Hope I helped!
Hope I helped!
Oh My GOD
I just received the GTR 42mm, and WHAT THE FCK !
This has THE worst vibration motor of all time !
Feel weak af, and makes more noise than a plane engine !
The worst product i have ever buy. I owned a lot of smartwatches, and i never got a watch with a soooo bad vibration motor.
Really, don't buy this piece of sht, you will regret it.
Even for free i wouldn't wear this joke
Same with the 47mm version of the GTR. It's more like an 1990s PC buzzer. Very loud and annoying.Wahoux ha scritto: 10 ott 2019, 11:22I just received the GTR 42mm, and WHAT THE FCK !
Visitano il forum: Google Adsense [Bot] e 1 ospite
