MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
hyippiemon
Post by hyippiemon »
[mention]cndjonno[/mention]
I don't know if that's an issue, but there are several examples which prove that it's possible to show all 12 months with 10 images.
MonsterDruide1
Post by MonsterDruide1 »
It expects 10 images because that's still a number. The 12 is built together of 1 and 2, so that's not an error.
The most obvious differences to this system are weekday and dayAmPm.
Maikeldevil
Been thanked: 44 times
Post by Maikeldevil »
Is there any way to create an status icon for "alarm"? I use the alarm a lot, it would be great to quickly see if my alarm is set or not.. Hope to hear from u!
lvpokka
Post by lvpokka »
No idea, 90% that it not possible.
cndjonno
Post by cndjonno »
[mention]hyippiemon[/mention] [mention]MonsterDruide1[/mention] Ah, I misunderstood the setting thinking it was to switch from numbers to text. That makes sense, so thank you for the help!
hyippiemon
Maybe I found a bug
I have the problem, that in one of my watchfaces i recognize a difference of the battery icon positions between preview and live picture on the band. I think 2 pixels to the left on the band.
Battery icon is the colored dash in the middle.
Numbers have all the same size.
"Status": {
"Battery": {
"BatteryConfig": {
"BoxWidth": 0,
"Alignment": 0,
"Order": 0
"Icon": {
"X": 46,
"Y": 122,
"ImageIndex": 31,
"ImagesCount": 9
The attachments show what I mean.
Maybe an error on my side?
Please take a look!
preview generated with MiBandWFTool
Image took with my smartphone
unnamedbig_blue_german_packed.bin
the bin
(26.58 KiB) Downloaded 213 times
lvpokka
Post by lvpokka »
hyippiemon wrote: 04 Sep 2019, 05:13
As i see there is shift for 1 px for Date and 1 px shift for battery... didn't saw this previously) maybe it's some miscalculations in alignments.Not critical, probably will shift back in next release.
Thx
hyippiemon
thanks, yes, seems to be an alignment (Center) issue
took "Left" now -> no difference between preview and live picture
hammad497
Post by hammad497 »
Hey I am having a problem. After following the procedure stated above i was able to generate a .bin file. After placing it in the respective folder i tried to sync the watch face in the mi fit app. But the app is stating "could not sync". I feel like i am making a dumb mistake. Can someone guide me? Thanks in advance.
MonsterDruide1
[mention]hammad497[/mention]
This error can have many sources, maybe try to add a preview into the folder so that you know it really is the correct watchface.
Also, did you generate the .bin with the Palette-Image mode or with the Raw-Mode? Try to do it with the Palette image mode, so there aren't too big/deep pictures.
lvpokka
Post by lvpokka »
hammad497 wrote: 04 Sep 2019, 23:43
99% size off your watchface is higher then 320kb
hammad497
Post by hammad497 »
Thanks guys! The problem was the size of the WF. Used the palette mode and it worked. Thanks again!
stqcb
Post by stqcb »
Hi there,
I'm having a similar problem as hammad497. I can confirm that for my problem it is indeed the size. But my question is, how do I get the size down.
When I try palette image mode it gives me the following error "This image is using too many palette colors. Please make image less colorful or use RAW". But when I try raw mode the total size with the changes I made is 492kb.
But here's the thing. The original .bin I'm working off of is 233kb. I tried simply dragging that to watchface.exe then immediately dragging the .json file from the uncompressed folder, completely unchanged, back to watchface.exe and the new .bin file is 402kb. How come the new file is so much larger even though there were no changes made to the .json code, or any of the images?
Again, I can't use palette mode because it gives me the above error.
Thanks for the help.
lvpokka
Post by lvpokka »
README) please check palette mode and raw.cfg
stqcb
Post by stqcb »
lvpokka wrote: 05 Sep 2019, 15:51
I assume you're talking about this part of the readme? "create file raw.cfg with content 1,4,2,5,66 (near .json) to force raw image mode for selected image IDs in raw.cfg"
I don't really know much about coding or anything so I don't know exactly what that means or how to do it.
Dario
Post by Dario »
GIK-Team wrote: 08 Jul 2019, 12:57
Stable v1.3.8
v1.3.9
[mention]GIK-Team[/mention] where is it possible to find version 1.3.8 ?
I have read that it is the best version (I have already tried other versions and other modified programs but they are full of bugs :cry: )...
I wanted to change the days (replacing them with those in Italian) in the bluegreen whatchface of [mention]lazimk[/mention] ...
Thank You :D
Bye
lazimk
Post by lazimk »
stqcb wrote: 05 Sep 2019, 13:43
Hi there,
I have a workround for this. a curvy path. (pack to RAW in 1.3.9, unpack with v1.3.6, then pack same with PALETTE 1.3.6, unpack with 1.3.9, pack again with PALETTE 1.3.9, its just to make sure jsons are in correct format)
I am gonna request this to be included as an option/feature in next version (posterize option)
-Laz
*Have a great day*
lazimk
Post by lazimk »
[mention]lvpokka[/mention]
In v1.3.8 and v1.3.9 (i think in both) when raw files are packed with PALETTE exe, it gives error (saying it uses too many colors, use raw.cfg), But in 1.3.6 it somehow posterizes/compresses the image to certain number of colors in palette. I have used this as a workaround in my works.
This is my request to add 'Force posterizing / paletting' as an option (0 or 1) for palette mode exe (on .config maybe).
This should not affect images in raw.cfg
This option will be helpful for ppl who want to include animation in wf and optimize size.
Please include this option in next version.
-Laz
*Have a great day*
Has thanked: 1162 times
Been thanked: 279 times
Dario wrote: 05 Sep 2019, 17:01
Thank You :D
Bye
MiBandWFTool_1.3.8.zip
(1.32 MiB) Downloaded 216 times
lvpokka
Post by lvpokka »
[mention]lazimk[/mention] sooo 1.3.6 just allowing to user more than 256 colors or its making image quality lower? there is certain limit and lag on MiBand4, could you please show background images after 1.3.9 raw and 1.3.6 after your tricks
p.s there is some problems if allow to use more palette colors(its just black, or not showing), did you test on miband4?.
lvpokka
Post by lvpokka »
[mention]Dario[/mention] i have more then 5 testers which is creating watchfaces on daily bases) could you explain where you have bugs in 1.3.9(better than 1.3.8)
lazimk
Post by lazimk »
v1.3.6 palette mode makes image quality lower (it doesn't say user that a particular image cannot be used). I lowers quality by palettizing image to certain number of colors (like Posterizing).
In v1.3.9 palette mode, tool doesn't posterize image, but says user to use an image with less number of colors.
(Mi band 4 can support 16mil colors, But heavy WFs make band laggy)
I am attaching 3 pictures here (same frame).
1) RAW (17.5 kb) has many colors
2) Posterized by v1.3.6 (14 kb)- has less number of colors in color palette, (compare both images)
3) Manually Posterized (6 kb) - has very few colors.
The feature i mentioned, if it can give an option to posterize images (on/off), if on, to a number of colors (user inputted number, like 64,128,256), it could be used to optimize WF size.
Image Image Image
-Laz
*Have a great day*
lazimk
Post by lazimk »
Also, In addition (as suggestion),
In generated previews, animations included in WF are repeating again and again even if i set RepeatCount = 1.
If Generated Preview could follow Repeat count , it would be nice
-Laz
*Have a great day*
lvpokka
Post by lvpokka »
[mention]lazimk[/mention] please check in 1.3.6 logs, is there message "[WARN] This image is using too many palette colors" because in 1.3.6 there was only warning but you get lucky, because i think it's cropping needed colors.
Yest it's support 16m colors) BUT In raw mode ;D
Please check how many colors its writed in bin
Trace|Palette item 369: R 78, G 74, B 70
what is the max number
upd.
Your definitely wrong but very lucky!
Just tested and found 1 bug and 1 new solution)) you can try to test and use some random "photo", it will become black)
BUT!!! i found bug, and currently on your example your JUST using 8bit image, so if you will convert in paint.net your image in 8bit, you will get even better result.
lazimk
Post by lazimk »
lvpokka wrote: 05 Sep 2019, 21:32
@lazimk please check in 1.3.6 logs, is there message "[WARN] This image is using too many palette colors" because in 1.3.6 there was only warning but you get lucky, because i think it's cropping needed colors.
upd.
Ah bro.
Yes.. I always used PNG-8 (8-Bit) images (thinking it would reduce packsize for Raw) . Maybe thats why i got lucky.
So, if it is planned to include that feature, palette exe might want to export pics to PNG 8bit, and apply posterization i guess.
-Laz
*Have a great day*
Users browsing this forum: DuckDuckGo [Bot] and 1 guest
