• 管理员
MiBandWFTool
版面规则
回复
lvpokka
来自: L1
Has thanked: 19 time
Been thanked: 152 time
联系:
MiBandWFTool
帖子 lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
上次由 lvpokka 在 02 8月 2020, 19:41,总共编辑 24 次。
Skar3
联系:
帖子 Skar3 »
Hi, are you planning to release the source code?
lvpokka
来自: L1
联系:
帖子 lvpokka »
Not right now) you want some new features?
Toan
联系:
帖子 Toan »
Hi, thank you for your work. I want to report a possible problem that i have found with calories indicator.
If i use only "Number" in my json all seems to be correct in preview but calories are shown in a different way in my MiBand4, in my case, aligned to the left instead of right and without background.
I used the other parameter "DelimiterImageIndex", the preview does not change and on MiBand calories are shown as they should but moved because there is the delimiter image on the last position on right (indicated by "BottomRightX").
I solved using a 1x1 pixels image as delimiter image and moving the last position 2 pixels to the right (1 for delimiter, 1 for spacing that i have set), calories are shown correctly on MiBand but moved one position to the right in preview.
I hope I was clear enough to help to understand this problem.
Titerinho
帖子 Titerinho »
lvpokka 写了: 21 8月 2019, 12:17
Weather was not supported by MiBand4 for now
Actually I did some testing and it turns out that ONLY the temperature is not supported. If you try to display just the weather icon, it works fine, which you can see in the image below.
If you try to use both weather icon and temperature, none of them will shop up. I wonder when Xiaomi will start supporting temperature too.
EDIT:
Go ahead and download my watchface, if you want to test it: https://amazfitwatchfaces.com/mi-band-4/view/4780
But I guess you were right, I did some more testing. It's only half-supported. The icon is displaying, but it's not updating. :lol:
lvpokka
来自: L1
联系:
帖子 lvpokka »
[mention]Titerinho[/mention] Let me guess you always have a picture of the night? :DDDD First icon of array in your case moon means "Error" or "No Weather"
p.s Anyway thanks for testing and checking for some weather features. Sometime it could help allot)
Titerinho
帖子 Titerinho »
lvpokka 写了: 23 8月 2019, 08:46
@Titerinho Let me guess you always have a picture of the night? :DDDD First icon of array in your case moon means "Error" or "No Weather"
Yes I always have a picture of the night, haha :D I thought it was working, because I was testing it at night :lol:
I guess we just have to wait for a firmware update from Xiaomi. I also wonder why when I have weather only, the icon is visible, but when I want to show both weather icon and temperature, then both are not visible...
sml_boor
帖子 sml_boor »
Anyone has any idea why when creating WF using Raw mode on 1.3.8 I'm getting a 315kb .bin out of 32kb (total) of .png images?
Palette gives me a 106kb .bin out of same files
lvpokka
来自: L1
联系:
帖子 lvpokka »
sml_boor 写了: 24 8月 2019, 17:03
Read article https://en.wikipedia.org/wiki/Indexed_color
ormaken 写了: 24 8月 2019, 16:14
Can I apply a parameter "Z" or "Z-index" to "Time"? I would like that to appear above "StepsProgress".
Not possible, rendering order is predefined (at least for now)
sml_boor
帖子 sml_boor »
[mention]lvpokka[/mention]
Ok, I did a thorough read of that wiki page. I do understand why palette mode is smaller. My question still stands though - why my 32kb of .png turns into 315kb of .bin? I don't think i can reduce the .png files any more
lvpokka
来自: L1
联系:
帖子 lvpokka »
[mention]sml_boor[/mention] it's not using PNG format, mi band storing images in BMP with compatibility of full transparent pixels...
PNG format used just for transparency in image editors
lazimk
来自: India
Has thanked: 5 time
Been thanked: 4 time
联系:
帖子 lazimk »
in bandbbs.cn i have seen a GUI tool which allow you to see realtime preview and edit coordinates in json, compress and decompress bin file and resource file , etc. (some Mihuan tool v4.20 being latest).
Can we have a english translated version of that.
Or something similar tool ?
They also have a font file creation tool, using which u can change font file for MiBand4
-Laz
*Have a great day*
lvpokka
来自: L1
联系:
帖子 lvpokka »
Sorry but its not my part of job :D i home one my friend will release some king of version
MonsterDruide1
帖子 MonsterDruide1 »
I've made a GUI-Builder for Watchfaces. It's based on the functionality of Drag'n'Drop and supports most of the elements so far. It's available in German and English, but I can add more languages on request. It's avaliable on Github, please search for "MiBand4-WatchfaceEditor" or this link: https://github.com/MonsterDruide1/MiBan ... r/releases . The controls are intuitive (I hope), otherwise they can be found in the README-file.
I published this first version a few days ago, so it may contain bugs or there could be features missing. If that's the case, please adress me here or via the "Issues"-Tab on GitHub.
w0mbat
来自: France
Has thanked: 3 time
联系:
帖子 w0mbat »
sml_boor 写了: 24 8月 2019, 18:21
@lvpokka
Have you checked the number of times you call your 32kb pngs in your JSON?
viewtopic.php?f=25&t=744&p=2006#p2006
头像
becamer
来自: unknown
联系:
帖子 becamer »
Is there an option to edit priority of image displaying? I mean a layer priority like "z-index" in CSS. For example: if I have a weekday and date image in the same place, I want to change its z-index that one of it would show under or above the second image. This is required for the theme I'm creating so I'll be grateful for any advice.
lvpokka
来自: L1
联系:
帖子 lvpokka »
Not possible...
b.t.w
v1.3.9
https://yadi.sk/d/t-gN9dmQN4myzA
lazimk
来自: India
Has thanked: 5 time
联系:
帖子 lazimk »
[mention]lvpokka[/mention] Thank you so much for releasing v1.3.9
btw, what do you mean by "TimeElement DrawingOrder hardcoded to 1234 (not used by MiBand4)"
Can you explain ?
Does it mean it always render/draw hour 10 first, then hour 1, then minute 10 and then minute 1 ??
Why is it hardcoded now if it could be customized??
-Laz
*Have a great day*
lvpokka
来自: L1
联系:
帖子 lvpokka »
[mention]lazimk[/mention]
Do you have proofs? do you have any watchface which on MI band 4 has order not like 1234 (12:45)-( hour 1 hour 2 minute 4 minute 5)
please build it with 1.3.8
lazimk
来自: India
Has thanked: 5 time
联系:
帖子 lazimk »
I have not personally made different cases. But i will give you these examples.
In different WFs i have made, i used same order only (example : https://amazfitwatchfaces.com/mi-band-4/view/5073)
But, lets take those 2 stock WFs available in band (Orange and Blue) , they have Hour digits drawn on top of Minute digits. (right?)
Which makes me think it is possible.
Edit: I tried changing order of appearance of element (by lines) in json (since something like order attribute is not available yet). Its not working in v.1.3.8
But i believe such thing is possible as we can see in stock WFs
-Laz
*Have a great day*
lvpokka
来自: L1
联系:
帖子 lvpokka »
[mention]lazimk[/mention] yeap) thx for testing, we also trying to find order or parameter for that, but for now, order is not working) Thats why on preview order will be always 1234
lazimk
来自: India
Has thanked: 5 time
联系:
帖子 lazimk »
Thanks.
Can u mention how you guys are doing this reverse engineering or finding order / parameters, parsing parameters, what tools are used. Etc?
(If it is okay)
-Laz
*Have a great day*
jfpolaniar
Has thanked: 3 time
联系:
帖子 jfpolaniar »
Hello, I would like to know if the weather can be added. I try to edit a watchface but not let it load in the Mi Band 4
https://amazfitwatchfaces.com/mi-band-4/view/799
附件
fallout_pipboy_spa_packed-40104-a76eddd7a3_packed.bin
(395 KiB) 已下载 183 次
lazimk
来自: India
Has thanked: 5 time
联系:
帖子 lazimk »
[mention]jfpolaniar[/mention] from my understanding by reading posts from this thread,
weather does not work in MiBand4 Watchfaces.
even it show some weather icon / temperature, they are not correct (does not update as well).
So, weather does not work (alteast for now).
-Laz
*Have a great day*
lazimk
来自: India
Has thanked: 5 time
联系:
帖子 lazimk »
There is a BETA firmware v.1.0.6.06 released for Mi Band 4. I wonder what changes it brings.
-Laz
*Have a great day*
cndjonno
帖子 cndjonno »
Found an issue under "MonthAndDay" when "TwoDigitsMonth": false, in order to use months in text format the program still expects 10 images instead of the 12 and my November and December do not display correctly.
Great job by the way and if you have a link to github, I could try and see where the issue lies. Keep up the great work!
回复
回到 “Watchfaces tools”
在线用户
正浏览此版面之用户: 没有注册用户 和 1 访客
