Amazfit watchfaces Tool
alexandrecn1985
Even with the latest version of the tool I keep getting inverted colors on my Verge Lite, there's any known issue about that?
侯侯大神
- Has thanked: 2 times
- Been thanked: 4 times
- Contactar:
It seems that the WF package will fail(https://amazfitwatchfaces.com/verge-lite/view/64). I want to generate a preview gif.
Hi, I unpacked a bin, modified the background of the image and repackaged. But when installed on the watch the arms do not appear, and also to change the colors of the dial.
kvatebriga
- Contactar:
Hi! I got Amazfit GTR and want to create my own watchface. As I know GTR screen has resolution 454x454. In AmazTool "Pack" and "Unpack" is size 464. Thats make "rotating hands" out of center. If i change "-size464" to "-size454" it does not work at all. Hmm, can anyone help me?
PavlinBecks
- Contactar:
so after a few attempts, I still have a problem with the colors on Verge Lite. I couldn't figure out the context of different images, some work some not and still invert or poorly display colors. Please someone more experienced to advise me.
Hi, did you get an answer? I have the same concern.
I've been building a GTR face. When I try to push it to my watch, it sits there working for quite a while. When the progress bar gets to the end it reports "Couldn't sync, try again." Any idea why this is?
Steve VB
Ontario, Canada
GTR 47 User
Ontario, Canada
GTR 47 User
cloporte
- Contactar:
Nope, but i found out i could subscribe to amaztools beta program using testflight
on IOS device they already release some new version
maybe i will try to download a facewatch from here and upload using amaztoolbox .
Will see
manelto
Has anyone found the system to get the correct colors in the watchfaces?
Just unpack and re-pack again without any mod. The color has been changed. Is it bug? Any solution? using the latest tool version 0.1.0.11. This is for GTR.
Última edición por hall el 22 Ago 2019, 02:58, editado 1 vez en total.
- siddartha001
- Has thanked: 4 times
- Been thanked: 2 times
- Contactar:
Hmmm i can not find the "Unpack i GTR file in the zip. I create my first WF but the colours locks not correct in the Watch.
Any can help?
Any can help?
thiagoellis
- Contactar:
I edited a file that has animation, just as shown in this tutorial (https://amazfitwatchfaces.com/blog/crea ... hfaces-bin), but when you pack the files it changes the animation images from "png" to ".dat", only the first animation image continues "png". How to solve?! MiBand4
manelto
I can not understand it. There are users on this website who are designing watchfaces without problems (with the correct colors). What applications do they use?
manelto
I don't know the solution to the problem of colors. But when comparing the Osmat program (in C #) and the afwafwafw program (in Python), I can see that in the module reader there is a difference: in Python the color order is B, G, R, alpha and in the C # program is R, G, B, alpha. Maybe this is the problem. I do not know. :C
- Yosscal
- Been thanked: 3 times
- Contactar:
First, thanks for this tool!
With this tool, I intend to make a watch face of the Diesel DZT2010 (Diesel’s neon-soaked) for my GTR.
But something tells me that it's not going to be that simple as I believe it,between the displacement of the dials,cutting needles,and the glow of the numbers.
I will try and if I succeed, I will be happy to share it here!
jlsh007
I tried to unpack my gtr bin file, even tried unpack i but the background image color completely changed.
So I manually edit the background image and pack it again. When I upload to my watch the color changed again.
Is there any easier way just to change the time hand image for the hour, minutes and second?
HI there,
i am trying to unpack a watchface and receive the following error (sorry, it's german language, but maybe someone recognizes the error).
Am i missing something? Does anybody now a solution?
Thanks in advance!
Código: Seleccionar todo
.\WatchFace.exe -size464 .\GTR.bin
Processing file '.\GTR.bin'
Opening watch face '.\GTR.bin'
Reading parameters...
Parsing parameters...
Parameter does not exists (WatchFace.Parser.WatchFaceGTR)
System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei WatchFace.Parser.Utils.ParametersConverter.Parse[T](List`1 descriptor, String path) in E:\Works\Escorp Dynamics\Lab\Exomode\amazfitutils\WatchFace.Parser\Utils\ParametersConverter.cs:Zeile 89.
bei WatchFace.Program.ParseResources(Reader reader) in E:\Works\Escorp Dynamics\Lab\Exomode\amazfitutils\WatchFace\Program.cs:Zeile 396.
Thanks in advance!
- Yosscal
- Contactar:
I finished the creation of the Diesel's neon-soaked for GTR, but I also have the color problem, all the blue are green, the white is pink etc ...Yosscal escribió: 22 Ago 2019, 17:27First, thanks for this tool!![]()
When the .bil file is decompressed, I get the message "Found 2 bytes gap before resource number 0" in the decompression list. normal or not?
Processing file 'GTR.bin'
Opening watch face 'GTR.bin'
Reading 48 resources...
Reading resource 0...
Reading resource 1...
Reading resource 2...
Reading resource 3...
Reading resource 4...so i'm wondering if there is not a problem when decompressing or recompressing the .bin file?
Última edición por Yosscal el 23 Ago 2019, 10:09, editado 1 vez en total.
manelto
I downloaded Visual Studio Community from Microsoft and tried to compile the source, but I have two errors: amazfitutils.csproj or test.csproj cannot be foundosmat escribió: 14 Ago 2019, 12:36We share the source with you, please share your best practices with us))))
Thank you!
manelto
Thanks Osmat. But that version, already compiled, has the problem of colors with the GTR. I tried to compile it again, changing a file (reader.cs). But when I compile it I get the error that two files are missing amazfitutils.csproj and test.csproj.
I want to try changing the read32bitimage function.
the lines:
for (var x = 0; x <_width; x ++)
var b = rowBytes [x * 4];
var g = rowBytes [x * 4 + 1];
var r = rowBytes [x * 4 + 2];
var alpha = rowBytes [x * 4 + 3];
changing the order of variables b and r.
Rur77
seems like changing colors will not help because of gray colors with same r\g\b also looks ugly on GTR. seems like it place alpha instead of some color too.
¿Quién está conectado?
Usuarios navegando por este Foro: Baidu [Spider] y 1 invitado
