py amazfit tool
afwafwafw
Been thanked: 14 times
py amazfit tool
Post by afwafwafw »
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
TXK
Has thanked: 149 times
Been thanked: 97 times
Post by TXK »
Can you make EXE programs?
afwafwafw
Post by afwafwafw »
Sure but not right now.
You can generate it by executing auto-py-to-exe, though.
fx_advanc
Has thanked: 7 times
Post by fx_advanc »
cool bro,
i have using it today, straight forward. but no animation.
afwafwafw
Post by afwafwafw »
Yes, you're right.
It's a little trick but you can get animation .gif after unpacking packed_bin again.
i.e
python main.py WATCH_FACE.json # now you've got WATCH_FACE_packed.bin
python main.py WATCH_FACE_packed.bin # in WATCH_FACE_packed/ folder you can see gif file in there
侯侯大神
Post by 侯侯大神 »
Why can't you use your tools to unpack your bin, only unpack the official ones
fx_advanc
Post by fx_advanc »
I need to get the live editor, easier to locate the dial .png files to X & Y coordinate.
Do you have any guide tool for numbering x 1-360 x y 1-360 grid
AFWAFWAFW
afwafwafw
Post by afwafwafw »
侯侯大神 wrote: 22 Aug 2019, 04:13
I always use mine to pack/unpack my .bin.
Have you tried latest version of my tool?
Which bin cause issue for you? Can you give me a link for it?
afwafwafw
Post by afwafwafw »
fx_advanc wrote: 22 Aug 2019, 08:41
AFWAFWAFW
Hi. I'm using GIMP as a guide tool. :)
侯侯大神
Post by 侯侯大神 »
Thanks for replying, friend, I should not be using the latest version
manelto
Post by manelto »
Is It possible have this tool for GTR amazfit?
afwafwafw
Post by afwafwafw »
manelto wrote: 22 Aug 2019, 17:45
As I don't have a GTR watch, I cannot make the tool for GTR easily. There's one person who forked mine. He've changed the name as amazfit_gtr_tools so you can wait for his work or Amazfit watchfaces tool(posting.php?mode=quote&f=26&p=2400).
afwafwafw
Post by afwafwafw »
侯侯大神 wrote: 22 Aug 2019, 11:02
No problem. If you have any issue, let me have .bin for debugging.
manelto
Post by manelto »
afwafwafw wrote: 22 Aug 2019, 21:54
OK! Thank you.
The problem seems to be the resolution (360 vs 454) and the header (header.bin). But maybe there is something else (sure: D).
manelto
Post by manelto »
viewtopic.php?f=29&t=782&p=2423#p2423
fx_advanc
Post by fx_advanc »
Does gimp shows the coordinate? what name of the features.
afwafwafw
Post by afwafwafw »
fx_advanc wrote: 24 Aug 2019, 14:53
https://docs.gimp.org/2.10/en/gimp-conc ... uides.html
Right?
fx_advanc
Post by fx_advanc »
Can you help me position the dial, thanks [mention]afwafwafw[/mention]
here's the link " https://justbeamit.com/89pag
afwafwafw
Post by afwafwafw »
here's corrected version for tick.zip
https://drive.google.com/open?id=1xT_ct ... ou1v-q5cXv
Just remember that let "CenterImage.X", "CenterImage.Y" equal to pin position of time hands.
By comparing it with original tick.json, you can see how to set position of hands.
fx_advanc
Post by fx_advanc »
yep been trying, i tried to set EMC first,
tick.json i forgot where did i put the original file (i take it from verge).
afwafwafw
Post by afwafwafw »
TXK wrote: 19 Aug 2019, 02:02
https://github.com/ghtalpo/amazfit_verg ... ease/win32
see usage/for_windows_users section in readme.md
Ferodo
Post by Ferodo »
afwafwafw wrote: 26 Aug 2019, 13:23
Thank you so much :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
koolgao
Post by koolgao »
buenos dias compañeros para cuando https://github.com/ghtalpo/amazfit_verg ... ease / win32 este podra empacar las esferas de 42 mm del gtr? para el gtr de 47 va de lujo pero para el de 42 no hace nada
glenan
Post by glenan »
Hello
Is there any tuto how to use Amazfit GTR TOols 32b ?
Thanks.
