ZeppOS Player 2
Newest Release
CHANGELOG
v2.4.2
- Fixed project auto-reload so the first external file change is applied reliably. File changes are now briefly debounced until the project change token is stable, then exactly one runtime restart is performed.
- Fixed GIF dimensions after switching to a watch face for a different device size. Selecting a new watch face now performs a full runtime restart after device-profile detection, so GIF capture immediately uses the new screen dimensions without requiring a manual Restart Watchface/APP.
v2.4.1
- Added Random Auto-Increment as a separate playback mode. Simulated values are randomized independently while smooth-second and SECOND-based time remain synchronized to real time.
- Normal Auto-Increment and Random Auto-Increment are mutually exclusive and can be switched directly from the left toolbar.
- Fixed COMPASS CHANGE/CURRENT events so watch faces receive a Zepp-compatible compass result object, including calibration_status and direction_angle.
- Expanded the finished-watch-face runtime compatibility layer with HRV, BioCharge/HybridCharge, separate Beaufort wind and km/h wind-speed data, additional modern and legacy Zepp data types, sensors, widgets, and safer fallbacks for unknown data types.
- Improved modern app.json target selection, asset-path handling, intrinsic image sizing, and protection against zero-size render canvases.
- Added END_X/END_Y layout properties, layoutChange callbacks, API-level 4-style direct widget property access, typed SysPro persistence, and additional runtime compatibility modules.
- Fixed getForecastWeather initialization so watch faces using forecast data no longer fail during the initial resume_call, and stored forecast weather icons are now returned correctly.
- Forecast editor changes now immediately re-run WIDGET_DELEGATE resume_call so script-driven forecast displays update at once; per-day weather icon selection has also been restored.
- Moon phase now changes during normal Player playback as well as during randomized GIF recording.
Older Versions
VERSION 2.3
CHANGELOG
2.3.3 · September 17, 2026
2.3.2 · September 16, 2026
2.3.1 · September 16, 2026
2.3 · September 16, 2026
VERSION 2.2
CHANGELOG
VERSION 2.1
CHANGELOG
VERSION 2.0
TRANSLATE for v2.4
