ZeppOS Player 2
Lattenknaller
Has thanked: 62 times
Been thanked: 174 times
ZeppOS Player 2
Post by Lattenknaller »
Hi everyone,
ZeppOS Player 2
Newest Release
Download v2.4.3
CHANGELOG
- Fixed stale diagnostics after watchface reloads and project switches. Warning/error entries and compatibility counters now reset for the newly loaded watchface, so resolved warnings disappear automatically after an auto-reload without requiring Refresh/F5.
v2.4.2
- Fixed project auto-reload so the first external file change is applied reliably. File changes are now briefly debounced until the project change token is stable, then exactly one runtime restart is performed.
- Fixed GIF dimensions after switching to a watch face for a different device size. Selecting a new watch face now performs a full runtime restart after device-profile detection, so GIF capture immediately uses the new screen dimensions without requiring a manual Restart Watchface/APP.
v2.4.1
- Added Random Auto-Increment as a separate playback mode. Simulated values are randomized independently while smooth-second and SECOND-based time remain synchronized to real time.
- Normal Auto-Increment and Random Auto-Increment are mutually exclusive and can be switched directly from the left toolbar.
- Fixed COMPASS CHANGE/CURRENT events so watch faces receive a Zepp-compatible compass result object, including calibration_status and direction_angle.
- Expanded the finished-watch-face runtime compatibility layer with HRV, BioCharge/HybridCharge, separate Beaufort wind and km/h wind-speed data, additional modern and legacy Zepp data types, sensors, widgets, and safer fallbacks for unknown data types.
- Improved modern app.json target selection, asset-path handling, intrinsic image sizing, and protection against zero-size render canvases.
- Added END_X/END_Y layout properties, layoutChange callbacks, API-level 4-style direct widget property access, typed SysPro persistence, and additional runtime compatibility modules.
- Fixed getForecastWeather initialization so watch faces using forecast data no longer fail during the initial resume_call, and stored forecast weather icons are now returned correctly.
- Forecast editor changes now immediately re-run WIDGET_DELEGATE resume_call so script-driven forecast displays update at once; per-day weather icon selection has also been restored.
- Moon phase now changes during normal Player playback as well as during randomized GIF recording.
Older Versions
VERSION 2.3
Download v2.3.4
CHANGELOG
2.3.4 · September 17, 2026
2.3.3 · September 17, 2026
2.3.2 · September 16, 2026
2.3.1 · September 16, 2026
2.3 · September 16, 2026
VERSION 2.2
Download Release 2.2.1
CHANGELOG
VERSION 2.1
Download Release 2.1.3
CHANGELOG
VERSION 2.0
Release Start
Translate missing language
TRANSLATE for v2.4
Translations.xlsx
Lattenknaller
MarioLie wrote: 16 Sep 2026, 09:07
Preview
Added HUAWEI WATCH GT
Huawei
That won't happen; it is and will remain a ZeppOS-Player for Amazfit watches. But thanks anyway.
Has thanked: 441 times
Been thanked: 2142 times
I found the issue if use some widget's property, it will displaying not correctly in the simulator:
- Text image: The simulator displays incorrectly if the `angle` property is used.
- Text font: The simulator displays incorrectly if the `start_angle` and `end_angle`and `unit_type` property are used.
Please refer to the attached image.
Best regards,
Preview issue
Lattenknaller
I'll take a look at that. I was actually just about to release version 2.3 with the complete redesign of the windows. But feature updates take priority.
Lattenknaller
ZeppOS Player 2.3.4
Download v2.34
CHANGELOG
Thank you very much for adding this feature.
However, it appears that in the "Text image" section, the X and Y coordinates are displayed incorrectly after rotating the image.
Please see the attached image.
with Angle
without Angle
without Angle, it's no issue
Lattenknaller
Damn, thought I'd tested all the variations. A hotfix is online v2.3.4.
Been thanked: 1045 times
The text is cut off on the right-hand side
If you enable ‘Object Browser’, it isn’t visible. There might be a scroll bar at the bottom, but it isn’t visible.
The blocks are much too tall. That’s why a scroll bar is always displayed on the right, even if you hide all the blocks.
Lattenknaller
Thanks, I noticed that today, too, when I had to use my laptop for a moment. There will be a scaling update with the 2.4 release.
I am not sure if I am checking this correctly.
In the Zepp Player, if the alarm is set to 0 (rather than 0:00), the program does not display the "Alarm ON" icon.
However, in the ZeppOS Player, I cannot find a way to make the icon "Alarm ON" status non appearing.
Sample image
Lattenknaller
Right, my mistake.
For the alarm, there is now an additional option: 0 = OFF
When set to 0, ALARM_CLOCK still correctly returns false
This causes the “Alarm ON” status icon to disappear
Any time, such as 07:00, 09:30, etc., still means the alarm is active
Comes with version 2.4
Lattenknaller
Since v2.4 will take a while, I've already fixed a few bugs in 2.3.4.
- ALARM can now be set to 0-OFF
- Various custom scripts have been fixed
- Scaling for lower resolutions
Just download 2.3.4 again. The file has been replaced on the server.
Has thanked: 136 times
Been thanked: 21 times
Post by taw_bip »
Thanks for all the work on this. Maybe it's something simple I'm not understanding, but how do you re-open a watchface after it's been added to the projects folder?
taw_bip wrote: 18 Sep 2026, 15:21
You mean, once you've created the watchface folder inside the project folder, how do you open that watchface—is that right?
If yes, After you finish copying the files, simply click the "rescan projects folder..." button or F5. The watchface you copied to the project folder will then be added to the list.
Preview
Post by taw_bip »
Ah, yes. Now I see. I'm not sure how I missed that before. Thank you!
Lattenknaller
ZeppOS Player 2.4
Download v2.4.2
CHANGELOG
screenshot
Translation is missing from the project folder selection dialogue.
The compatibility block does not fit on the screen. With this block configuration, the Object Explorer block is not visible at all.
I’m not sure what’s causing it, but I’ve noticed some odd behaviour. I’m editing a file in the projects folder. The changes aren’t visible in the player until I perform some action that triggers a screen refresh. Then I change that same file back in the projects folder. And the change appears in the player automatically after a slight delay, without me having to do anything else.
Lattenknaller
SashaCX75 wrote: 21 Sep 2026, 16:52
screenshot
I'll finish the translation. As for the other problem, you can zoom in on the window. Set it to 90% (or even smaller) in the top-right corner, and you should be able to see the windows. Otherwise, you can also hide windows using the four buttons.
I'll take a look at that. Version 2.4.2 is coming anyway, because Asoo found another bug.
Lattenknaller
In the error report, this warning remains even if I switch to a dial that did not previously display such a warning.
SashaCX75 wrote: 21 Sep 2026, 19:29
I’ve encountered this issue as well; I have to press the refresh button or F5 every time I fix an error reported in the "warning" section to clear the notification. Otherwise, the notification persists even after the error has been resolved.
Lattenknaller
ZeppOS Player 2.4
Download v2.4.3
CHANGELOG
