ZeppOS Player 2
Lattenknaller
Has thanked: 61 times
Been thanked: 161 times
ZeppOS Player 2
Post by Lattenknaller »
Hi everyone,
ZeppOS Player 2
Newest Release
Download v2.3.4
CHANGELOG
2.3.4 · September 17, 2026
2.3.3 · September 17, 2026
2.3.2 · September 16, 2026
2.3.1 · September 16, 2026
2.3 · September 16, 2026
Older Versions
VERSION 2.2.1
Download Release 2.2.1
CHANGELOG
VERSION 2.1.3
Download Release 2.1.3
CHANGELOG
VERSION 2.1
Release Start
Future Versions
VERSION 2.4
Select a folder that contains incomplete works started with Editor 3 but not yet finished.
These will then be recognized in the player with the label “- Editor,” and you can test your unfinished WF files.
VERSION 2.X
If everything works and we're at nearly 99.9% Zepp compatibility, the next step is to develop our own editor.
But that's still a long way off.
Translate missing language
TRANSLATE
Translations.xlsx
Lattenknaller
MarioLie wrote: Yesterday, 09:07
Preview
Added HUAWEI WATCH GT
Huawei
That won't happen; it is and will remain a ZeppOS-Player for Amazfit watches. But thanks anyway.
Has thanked: 436 times
Been thanked: 2137 times
I found the issue if use some widget's property, it will displaying not correctly in the simulator:
- Text image: The simulator displays incorrectly if the `angle` property is used.
- Text font: The simulator displays incorrectly if the `start_angle` and `end_angle`and `unit_type` property are used.
Please refer to the attached image.
Best regards,
Preview issue
Lattenknaller
I'll take a look at that. I was actually just about to release version 2.3 with the complete redesign of the windows. But feature updates take priority.
Lattenknaller
ZeppOS Player 2.3.4
Download v2.34
CHANGELOG
Thank you very much for adding this feature.
However, it appears that in the "Text image" section, the X and Y coordinates are displayed incorrectly after rotating the image.
Please see the attached image.
with Angle
without Angle
without Angle, it's no issue
Lattenknaller
Damn, thought I'd tested all the variations. A hotfix is online v2.3.4.
