Everything and LiveView for balance 2
SleepyHollow
Has thanked: 30 times
Post by SleepyHollow »
Hello guys to all. Can someone help me and make these watchfaces as it is for balance 2. Please in perfomance watchface if it's possible add digital seconds and add 24h icon in am and pm place. These are free zepp watchfaces from store for amazfit bip max device. Thank you for your support. Have a nice day to all.
https://ze.mmk.pw/view/11206915/163897/1.0.2
https://ze.mmk.pw/view/11206915/167146/1.0.1
Has thanked: 428 times
Been thanked: 2131 times
SleepyHollow wrote: 09 Sep 2026, 07:25
If you really like the BIPMAX watch face, I would recommend buying a BIPMAX. Because, when the watch face is converted to a circular model, some of the original balance and visual harmony may be lost.
Everything_480x480.zip
(178.02 KiB) Downloaded 4 times
If I recall correctly, I remember seeing work by "GTR3PRO" associated with another one of your IDs, which suggests you know how to use the editor.
Regarding the other watch faceI didn't create for you: since it is possible to use sashaCX75's editor to extract the image files and rebuild the design without needing custom scripts, I thought you might want to try doing it yourself. Every widget on that watch face can be created using the editor.
SleepyHollow
Thank you, asoo!
