Has thanked: 14 times
@sadc
In AOD mode, there are no elements on the main screen. Consequently, the code attempts to modify a non-existent element, which causes an error. You need to add a check for the screen type.
This code doesn’t make sense. It will change the same elements three times.
sadc
Post by sadc »
SashaCX75 wrote: 31 Jul 2026, 12:23
@sadc
Thanks Sasha, the code is this one, already corrected not to "disturb" AOD:
for (let i = 0; i < 4; i++) {
	if (normal_forecast_low_text_font[i]) normal_forecast_low_text_font[i].setProperty(hmUI.prop.VISIBLE, false);
	if (normal_forecast_high_text_font[i]) normal_forecast_high_text_font[i].setProperty(hmUI.prop.VISIBLE, true);
	if (normal_forecast_average_text_font[i]) normal_forecast_average_text_font[i].setProperty(hmUI.prop.VISIBLE, false);
Guydu91
Has thanked: 58 times
Post by Guydu91 »
Watch Faces for Bip Max
Hello everyone,
I created watch faces for the Bip Max by converting designs from the Bip 6.
Since the aspect ratios differ, I am reworking the background to match the Bip Max screen dimensions of 432 × 514 (the conversion results in 532 × 498).
Everything looks fine and perfectly aligned during the design process in the watch face editor—as confirmed by the preview images (GIF or PNG).
However, users have reported that a small section at the bottom of the screen is missing, as if there were a black bar.
You can see this issue on these two watch faces:
https://amazfitwatchfaces.com/bip/view/45319
https://amazfitwatchfaces.com/bip/view/45397
Could someone tell me what I might be doing wrong in the design of these watch faces (and possibly others...)?
Thanks in advance for your replies.
Guy.
Has thanked: 421 times
Been thanked: 2128 times
Guydu91 wrote: 02 Aug 2026, 12:20
Hello everyone,
Guy.
The problem arises from the conversion. Because rectangular screens don't have consistent aspect ratios like circles, the program calculates an approximate value during the conversion. This might cause the settings to be inaccurate after conversion.
If you use the converted image, it will display completely because the converted image will also be 432 × 498.
However, when you change the image to 432x514, it will not display completely because the `w:` and `h:` files are still set to display at 432x498.
In this case, try looking at:
normal_background_bg_img = hmUI.createWidget(hmUI.widget.IMG, {
x: 0,
y: 0,
w: 432,
h: 498,
src: '0001.png',
and
idle_background_bg = hmUI.createWidget(hmUI.widget.FILL_RECT, {
x: 0,
y: 0,
w: 432,
h: 498,
color: '0xFF000000',
show_level: hmUI.show_level.ONLY_AOD,
In index.js,
you'll see that the display area definition is incorrect due to estimation during conversion. To fix this, change the `w:` and `h:` values ​​to match the actual screen size. In this case, `w: 432` and `h: 514` should resolve the issue. (The black area you see is because the `h:` (height) value isn't fully defined for displaying the image.)
Preview
If there were a screenshot, it would be clearer what this is all about. Not everyone can test the Bip Max.
asoo wrote: 02 Aug 2026, 12:43
In index.js,
I’ll check it out. It looks like an error in the editor.
Guydu91
Post by Guydu91 »
Hello everyone,
Guy.
x: 0,
y: 0,
w: 432,
h: 498,
src: '0001.png',
and
x: 0,
y: 0,
w: 432,
h: 498,
In index.js,
Preview
Thanks, Asoo, for the quick reply.
I'll take a close look at the index.js file.
Guydu91
Post by Guydu91 »
SashaCX75 wrote: 02 Aug 2026, 12:53
OK Sasha, a future version of the editor might solve the problem...
Thanks for the reply.
frankh93
Has thanked: 24 times
Post by frankh93 »
Guydu91 wrote: 02 Aug 2026, 13:12
I also ran into this issue and it was cause the image had a different dimension in height... just resize the image to the right dimensions (for bip max is 432x514) and you should be good
Guydu91
Post by Guydu91 »
frankh93 wrote: 02 Aug 2026, 17:22
Hi Franck,
That's what I initially thought: each time I converted from Bip 6 to Bip Max, I modified the background to match the dial height (514). But that's not enough, because it's clearly a problem with the editor.
Look at Asoo's reply: the solution is there... for now. A future version of the editor will fix the problem.
Best regards from France.
Guy.
Laurienzu
Post by Laurienzu »
Hello guys, I didn't manage to create a shortcut for the Hybridcharge function, I tried using an image and selecting shortcut but it didn't work anyway. Also is there any way to add a calendar shortcut?
For a more complicated question: I would like to create a multicolor watchface, basically when pressing a shortcut I would like to change the background, color of minutes, colour of day and color of circular bars. Is that possible somehow? Thank you
Laurienzu wrote: 05 Aug 2026, 17:36
Did you create the watchface with this program?
If you used the Hybridchart shortcut, you can create it using the Widget Button. Bio Charge , it's the same shortcut widget.
The calendar shortcut is the same; it's in the Widget Button. Calendar
For changing only the background, the editor also has this widget.
However, if you want to change other widgets as well, you need knowledge of JavaScript scripting to manage what you want
Laurienzu
Post by Laurienzu »
Wow thank you very much for your answer! I saw the Buttons but I didn't explore that function as I thought it should be under shortcuts like other things. Thank you!
Do you confirm that is possible then to change colour of other things through Javascript? I'm not the best programmer but maybe AI can help me, basically I would like one button that changes background and also color of other items, I will try to have a look :)
sadc
Post by sadc »
Laurienzu wrote: 06 Aug 2026, 06:55
Have e look at this code, it changes the background color and then first section changes the png image for the seconds hand, second changes the colour of a font text; for sure an expert can do much better, but it works :-)
andi182
Post by andi182 »
Hola, últimamente el editor me anda fallando al punto de qué me saca del programa y me salta la alerta de virus en mi ordenador y no me deja usar o re instalar. normalmente me sucede cuando armo una wf y selecciono la parte del qr.
Ayudaaaa, gracias!!
