AmazfitWatchFaces on the first GTR in 2025
Topics about Amazfit GT series watches and all the questions regarding their use, etc.
Alexking10
Post by Alexking10 »
I have an old Amazfit GTR 47mm from 2019. It was a gift for my graduation so I really would like to keep it.
I haven't turned it on for many months and I wonder if there is a way to use amazfitwatchfaces faces on my old GTR because I can no longer install watch faces with the AmazfitWatchFaces app. I synced my watch with Zepp and activated developer mode, but it seems that my model does not allow installation via QR code because "general" section is missing.
I knew about replacing the stock bin file, but it doesn't seem to work for Android 11 and above.
I tried to delete app, cache, data, resynch, but no results
Is there any way to install third-party watch faces on my old device?
Stas
Been thanked: 34 times
Post by Stas »
The Amazfit GTR 47mm only works directly over Bluetooth from the app, and sometimes the connection doesn’t establish immediately. Please check that there are no duplicate connections saved under your phone’s Bluetooth devices. If you see multiple entries for the watch, delete them all — the watch will then automatically prompt you to pair again. Don’t worry, this will not affect the connection in the Zepp app.
Alexking10 wrote: 01 Sep 2025, 15:29
Alexking10
Thanks but it did not work
GTR is correctly synched with Zepp.
I just try to install with BT with amazwatchfaces app but it always gives me error message
Stas
Post by Stas »
Could you please let me know which firmware version is currently installed on your GTR?
Alexking10 wrote: 02 Sep 2025, 16:52
Return to “Device discussion”
