Been thanked: 1044 times
v18.1
Version 18.1
Avoid_saikat
Post by Avoid_saikat »
Hi. I bought Active 2 few days back. Now I like a wf of Gtr 3 pro. But it's not available for Active 2. How can I convert it for active 2? I don’t need to change anything in wf. I JUST need it to fit in screen of active 2.
@Avoid_saikat
It all depends on the watch face. There are coded watch faces, and nothing can be done with them. There are watch faces with embedded user functions. In such cases, some of the coordinates may have to be changed manually in the code.
To convert simple watch faces, select the model you want to convert from and to on the Conversion tab and click the conversion button.
gnolooo
Post by gnolooo »
Is there a way to bundle various themes and/or languages into one watchface?
The idea would be to provide more assets and edit the files to achieve the following:
  • For languages, the watch would choose the active language, if possible, otherwise English by default.
  • For themes, the watch would let the user edit the watchface, without actually being able to edit any parameter, just the "color theme" (the same way the default watchface works, for example).
I created my own version, available in multiple languages and 6 color schemes, and the page looks quite cluttered:
These are just 4 languages, I plan to support more of them.
Plus, being able to bundle the themes would lead to more versions to choose from (since you can only have 1 custom watchface at a time, changing colour would require to download another one from the website; having them all bundled would give the possibility to change colour on the go).
gnolooo wrote: 20 Jul 2025, 16:44
In the editor, you can partially add themes to the watch face. It depends on which elements should change themes. You can change the background without any problems.
Using code, you can easily add multiple themes or multiple languages to the watch face.
frankh93
Has thanked: 26 times
Post by frankh93 »
@SashaCX75 could you help me? i'm trying to add shorcuts the way it has been working always for me (using buttons element and a png image), but now no matter what i do, if using these png images or colors the buttons wont work
Lattenknaller
Has thanked: 62 times
Been thanked: 167 times
Post by Lattenknaller »
Hello everyone,
Is it actually possible to hide elements in the AOD that have been hidden via script? In my case, the user can choose between analog, digital or hybrid display at the touch of a button. I would like to transfer this decision to the AOD, but so far I have simply not succeeded.
JerriBearr
Post by JerriBearr »
Lattenknaller wrote: 22 Jul 2025, 08:04
Hello everyone,
Hey there.
Have you tried to make the AOD clock widgets visible in the same way you are doing to your other normal widgets?
When you create the widgets in AOD on the Watch Face Tool, it will be generated similar to the other widgest with the postfix 'idle_'
let normal_background_bg_img = ''           // Background Normal
let normal_digital_clock_img_time = ''      // Clock Normal
let idle_background_bg_img = ''             // Background AOD
let idle_digital_clock_img_time = ''        // Clock AOD
In theory, you should be able to make these widgets visible/invisible in the same way that you are doing when not in AOD.
idle_digital_clock_img_time.setProperty(hmUI.prop.VISIBLE, true);
// or
idle_digital_clock_img_time.setProperty(hmUI.prop.VISIBLE, false);
Lattenknaller
Unfortunately, it's not that simple.
I'm not a beginner; I've already published one or two watch faces. .-)
JerriBearr
Lattenknaller wrote: 22 Jul 2025, 09:59
I am a beginner, so you can take my advice with a grain of salt. Just trying to help with programming suggestions :)
You can also try dynamically creating and destroying the seperate widgets when you press the button and depending on the state? I think I've read of someone having some luck with that.
gnolooo
Post by gnolooo »
I have a sort of bicolor watch, with some elements being in white and some others in an accent color. I'd like to switch between various accent colors.
What should I edit? Is there any documentation?
@frankh93
That means you're doing something wrong. Based on your description of the problem, this is the only answer I can give you.
Create a switchable background in the editor and enable its use on the AOD. Then look at the resulting code as an example.
The main problem is that in order to change something on the AOD, the code must also run on the AOD. Therefore, when turning on the screen, you need to check which screen is turned on. Only then should you run the necessary code.
gnolooo wrote: 22 Jul 2025, 15:34
https://docs.zepp.com/docs/watchface/ap ... tProperty/
Read the documentation on this website. And of course, you need to know JS, at least the basics.
You need to open the watch face as an archive and find the index.js file in it. You need to change the code in this file.
frankh93
Post by frankh93 »
@SashaCX75 managed to fix it removing the scripts i had and adding them again, thank you anyways.
btw got a question... theres a way to load the compiled watchfaces into the zepp emulator? cause wanna generate the gif preview but it wont make the part made in code, so was thinking on use the emulator but couldnt find a way to load it and take screenshots of it.
@frankh93
I don't know how to do it. Only to create a new project and copy all the code into it.
There is an unofficial editor. But the project is abandoned and not all widgets work in it.
You can take screenshots of the clock screen and then compile them into a gif file.
@frankh93
frankh93
Post by frankh93 »
@SashaCX75 ok gonna give it a try... Just one more thing, is there a way to make the watch vibrates as feedback when touching any button? I have read the docs of zepp, it worked but sometimes it doesn't vibrate
Lattenknaller
SashaCX75 wrote: 22 Jul 2025, 17:23
Thank you very much, I had already gotten that far. I also know that I have to transfer it somehow in the “widgetDelegate” area, but all my attempts have failed.
Maybe someone else has an inspiration.
let elementnumber = 1
let total_elemente = 3
let screenType = hmSetting.getScreenType();
function click_HYBRID() {
            if(elementnumber==total_elemente) {
            elementnumber=1;
                UpdateElementeOne();
            else {
                elementnumber=elementnumber+1;
                if(elementnumber==2) {
                  UpdateElementeTwo();
				if(elementnumber==3) {
                  UpdateElementeThree();
	    if(elementnumber==1) hmUI.showToast({text: 'HYBRID WATCH'});
            if(elementnumber==2) hmUI.showToast({text: 'DIGITAL ONLY'});
	    if(elementnumber==3) hmUI.showToast({text: 'ANALOG ONLY'});
function UpdateElementeOne(){
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_digital_clock_img_time) normal_digital_clock_img_time.setProperty(hmUI.prop.VISIBLE, true);
   if (screenType == hmSetting.screen_type.AOD && idle_digital_clock_img_time) idle_digital_clock_img_time.setProperty(hmUI.prop.VISIBLE, true);
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_analog_clock_time_pointer_hour) normal_analog_clock_time_pointer_hour.setProperty(hmUI.prop.VISIBLE, true);
   if (screenType == hmSetting.screen_type.AOD && idle_analog_clock_time_pointer_hour) idle_analog_clock_time_pointer_hour.setProperty(hmUI.prop.VISIBLE, true);
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_analog_clock_time_pointer_minute) normal_analog_clock_time_pointer_minute.setProperty(hmUI.prop.VISIBLE, true);
   if (screenType == hmSetting.screen_type.AOD && idle_analog_clock_time_pointer_minute) idle_analog_clock_time_pointer_minute.setProperty(hmUI.prop.VISIBLE, true);
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_analog_clock_pro_second_pointer_img) normal_analog_clock_pro_second_pointer_img.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.AOD && idle_analog_clock_pro_second_pointer_img) idle_analog_clock_pro_second_pointer_img.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_analog_clock_time_pointer_second) normal_analog_clock_time_pointer_second.setProperty(hmUI.prop.VISIBLE, true);
   if (screenType == hmSetting.screen_type.AOD && idle_analog_clock_time_pointer_second) idle_analog_clock_time_pointer_second.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_stress_icon_img) normal_stress_icon_img.setProperty(hmUI.prop.VISIBLE, true);
   if (screenType == hmSetting.screen_type.AOD && idle_stress_icon_img) idle_stress_icon_img.setProperty(hmUI.prop.VISIBLE, true);
function UpdateElementeTwo(){
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_analog_clock_time_pointer_hour) normal_analog_clock_time_pointer_hour.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.AOD && idle_analog_clock_time_pointer_hour) idle_analog_clock_time_pointer_hour.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_analog_clock_time_pointer_minute) normal_analog_clock_time_pointer_minute.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.AOD && idle_analog_clock_time_pointer_minute) idle_analog_clock_time_pointer_minute.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_analog_clock_time_pointer_second) normal_analog_clock_time_pointer_second.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_stress_icon_img) normal_stress_icon_img.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.AOD && idle_stress_icon_img) idle_stress_icon_img.setProperty(hmUI.prop.VISIBLE, false);
function UpdateElementeThree(){
   if (screenType == hmSetting.screen_type.WATCHFACE && normal_digital_clock_img_time) normal_digital_clock_img_time.setProperty(hmUI.prop.VISIBLE, false);
   if (screenType == hmSetting.screen_type.AOD && idle_digital_clock_img_time) idle_digital_clock_img_time.setProperty(hmUI.prop.VISIBLE, false);
Has thanked: 438 times
Been thanked: 2141 times
Lattenknaller wrote: 23 Jul 2025, 06:24
            elementnumber=1;
            else {
I'm not sure if I understand correctly.
When you select an element on the main dial, when you enter aod, it will change according to the main dial. If I understand correctly,
This is the script I tried. It works properly on my bip6.
I can't test it on the balance because now I am on my work out of my province I hope I understand correctly and it's useful for you.
Note : use SysProSetInt
Preview and project
Project open on Watch face editor for Amazfit watch on ZeppOS
aod.rar
(48.64 KiB) Downloaded 94 times
Lattenknaller
Looks good and I Love it.
Will test it tomorrow, but will say Thank you today
@asoo
many many thanks, work like a charm
and the solution was so simple :roll:
https://amazfitwatchfaces.com/balance/view/4543
frankh93
Post by frankh93 »
@Lattenknaller sorry to mention, it's a cool watchface but it comes to my attention you are running it in an emulator or something like that (cause I can see a mouse pointer in the preview)... If so, could you tell me what you used? Ty
Lattenknaller
@frankh93
It's called Zepplayer.
seythegamer
Post by seythegamer »
I really appearcite you work on this program, already made few watchfaces.
Im thinking about making something way different than anything already created by community, but unfortunately i cannot make .gif or .webp animations to work for me (Weather Icons)
Will animated files be supported in future releases? Is it possible?
@seythegamer
The watch cannot work with gif files, only with png files. There is animation in the watch faces, it is done with a set of png files.
marrud12
Post by marrud12 »
When I unpack Version 14.1.1 and start Watch_Face_Editor_(ZeppOS).exe in Win11, accept security-quesition of Win, nothing happens. Has somebody an idea whats is wrong?
