Request (GTR4): OnePlus 2 Watchface / Oppo Watch X2 Watchface
deepblue2000
Post by deepblue2000 »
I have searched the forum but found no request yet.
If some Watchface creater has some time and fun to create a Watchface for GTR4
I would like to prefer the OnePlus Watch 2 one:
https://static02.galaxus.com/productima ... _1000.avif
But if there is still fun and time I would take the Oppo one too.
https://image.oppo.com/content/dam/oppo ... thumb.webp
A donation will be possible for sure !
Thx
Has thanked: 441 times
Been thanked: 2142 times
deepblue2000 wrote: 16 May 2025, 20:00
Thx
I am interested in helping you make a OnePlus Watch 2 face.
I don't want to receive any donate, but if you want to donate, I recommend Donating to
sashacx75 for his Program editor ( viewtopic.php?p=11643#p11643 )
Donate to him : https://buymeacoffee.com/sashacx75
Because without the editor he created, I would not be able to make this watchface easy and comfortably.
📦 Download
OnePlus2_GTR_4.zip
(402.92 KiB) Downloaded 132 times
Oppo Watch X2 :
viewtopic.php?p=20511#p20511
deepblue2000
Big thx for the fast and great work. But could it be, that it shows the wrong time ?
deepblue2000 wrote: 17 May 2025, 11:09
If you mean the hour hand is showing the wrong time, I think it is working correctly because
The watch face should work properly as shown in the example.
From the example you attached, you can see that it is a 24 hour analog, so the hour hand does not move the same as the Analog 12. If you look at the example you sent, the bezel will be the numbers 1-24, not 1-12.
deepblue2000
It is now 13:30 but the Watchface shows 18:30.
I think the bezel numbers are not the clock hours
deepblue2000 wrote: 17 May 2025, 11:29
I'm not sure why you think like that, but in the editor it shows correctly, so I might not be able to fix anything, and I don't have a GTR4 so I can't test it, but anyway I tested it on Bip6 and it shows the time correctly in 24H format.
And from the many dials I've seen, I'm sure the bezel with the numbers 1-24 is the hour unit.
If you think it's not 24h, what do you think it is? Because if it's not a 24-hour analog dial, I don't know how to make a clock with hands that go with those numbers.
Or if you want a 12h analog clock, you can take the dial I made and modify it yourself as you wish. I will not proceed with anything else as previously stated.
link Editor Program :
Thx
Oppo Watch x2
📦 Download
Oppo_GTR_4.zip
(226.44 KiB) Downloaded 140 times
OnePlus 2
viewtopic.php?p=20505#p20505
deepblue2000
asoo wrote: 17 May 2025, 12:02
I did change it to 12h format, now its correct. time will be shown correctly now
TyDar
Post by TyDar »
Could someone be so kind as to convert this for GTR3 format for us diehards? I would, but my pc will not let me install the editor. This would be GREATLY appreciated! Thank you.
deepblue2000
TyDar wrote: 22 May 2025, 22:49
converted to gtr3
OnePlus2_GTR_3.zip
(397.83 KiB) Downloaded 96 times
Oppo_GTR_3.zip
(226.91 KiB) Downloaded 95 times
