OMG 348 for balance
- Has thanked: 205 times
- Been thanked: 5 times
OMG 348 for balance
Hello, guys! Can someone port this watchface for balance with ability to change colour like original. Thank you.
https://www.facer.io/watchface/6jj1K6DR ... atch4black
Lattenknaller
- Has thanked: 62 times
- Been thanked: 168 times
I've changed it a little, hope that's okay.
Or do you have any other suggestions?
If that works, I'll continue, all that's missing is AOD and the color change. UPDATE
WF is ready, I just can't find the script for the 24h icon anymore.
Publication then shortly
Awesome and perfect! Thank you, Lattenknaller. Always be fan of your works.
Lattenknaller
New problem: WF is ready, see attachment. but.....
My watch does not recognize the .tff and unfortunately does not display any values.
You can test it yourself.
Unfortunately, I don't have the time or inclination to create all the fonts using an image.
Maybe someone else will take pity on me
- Attachments
OMG348.zip- (306.88 KiB) Downloaded 113 times
Thank you anyway. Maybe someone from the skilled creators can help.
- Has thanked: 438 times
The font is not displayed because the font used is not TTF.
Most fonts obtained from facer are OTF. Although the editor can display it correctly, it may not be displayed on the clock.
Therefore, if you want to use a font, make sure it is TTF or, if it is OTF, convert it to TTF before using it.
Example convert online
https://cloudconvert.com/otf-to-ttf
fixed ( convert OFT to TTF)
Test on My Amazfit Balance work normal
Fixed X,Y 24H icon : viewtopic.php?p=20226#p20226
Lattenknaller
Thank you for that.
Quick question: how can I tell whether the .ttf needs to be converted?
I have downloaded this font as .ttf and not as .otf
The easiest way is you can check it is otf or ttf by use the windows font viewer that is built into windows.Lattenknaller wrote: 01 Apr 2025, 09:06Thank you for that.
Or you can right click on the font file and view the file properties.
Thank you both, asoo and Lattenknaller for this awesome watchface. One question, how can o add 24h icon in empty square box?
amazfitfacesafrica wrote: 01 Apr 2025, 09:50Thank you both, asoo and Lattenknaller for this awesome watchface. One question, how can o add 24h icon in empty square box?
