I used to purchase and use Mi Band Maps
but for now it does not work anymore with the newest google map version, then I have to switch to Mi Maps SmartBand and it work perfectly with newest google map version, UI simple, easy for setup. If you also meet the same problem with me and using navigation so frequently then we have the solution.
Get google maps navigation on Bip
wally86
I can confirm Google maps works using notify and fitness for amazfit.
