issue smooth seconds[SOLVED]
Omaradsl
Has thanked: 16 times
Been thanked: 8 times
Post by Omaradsl »
Hi to alls.
Howsolve the problem with issue smooth seconds , animation in firmware ( 3.22.15.7 )???
i see that Asoo and other upload a new version with fix.
I have last version of watch faces editor of Sasha.( 11.2)
but i have still problem with smooth second.
Thanks bros
Has thanked: 438 times
Been thanked: 2141 times
Omaradsl wrote: 04 Oct 2024, 15:57
Hi to alls.
Thanks bros
I recommend that you show the link of the dial you made and have the problem
so that those who want to help you can check it.
I test to unpack and repack your OAD42 watch face with version 11.2 and tested on my BALANCE , it can display smooth seconds correctly, so I am not sure why you having the problem as you mentioned.
Example of watch face repacked with 11.2
OAD42.zip
(349.06 KiB) Downloaded 164 times
Omaradsl
Post by Omaradsl »
sorry asoo, you're right, I wasn't very precise in describing the problem, and I thank you for your answer.
the problem noted is that the hand goes back one second in the cycle in which the dial is turned on. I attach the video to you.
https://drive.google.com/file/d/1Y347-g ... sp=sharing
see 3 seconds
and 8 seconds
the wathfaces is this:
https://amazfitwatchfaces.com/balance/view/1808
Omaradsl wrote: 05 Oct 2024, 08:53
see 3 seconds
and 8 seconds
From your example video, I think it works properly.
Smooth seconds may have some minor lag, like the video you showed.
This could be due to several reasons, such as:
- The watchface has a many animation, which may affect the smooth seconds.
- The image of the seconds face is too large.
- FPS setting.
However, the smooth seconds you showed as an example works properly.
If you want it to work more smoothly, you may try changing the FPS value to get the movement you want.
However, setting the FPS too high may affect the accuracy of the seconds slightly.
Example :
- changing FPS value
Video
OAD52.zip
(261.63 KiB) Downloaded 173 times
Omaradsl
Post by Omaradsl »
WOW, now is ok.
your change png immage and remove trasparent backround and set 99 fps fix the problem.
thaks Asoo.
