Watchface request for gtr3
Pyczek
Post by Pyczek »
Hi all, can someone please make this orb analogi face for GTR3 please?
https://www.facer.io/watchface/3njYOqo8 ... del=gears3
Has thanked: 438 times
Been thanked: 2142 times
Pyczek wrote: 08 Aug 2024, 05:16
Change center temp. to max min temp ( Because ZeppOS 1.0 cannot use "center temp" vaule on the circle )
Orb_Analogi_V1.01_GTR_3.zip
(190.13 KiB) Downloaded 115 times
Pyczek
Post by Pyczek »
Beautiful job. It looks amazing. Thank you very much.
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
Nice, but unfortunately @asoo current temperature isn't displayed at all on top, still on Gtr 3 it's not possible to display temp there? No one found a fix for this? I'm just curious ;) awesome job on this wf as always!
TRK88PL wrote: 08 Aug 2024, 17:07
Thank you very much for reporting the issue.
Since I haven't used GTR3 for a long time, I forgot that ZeppOS 1.0 can't display center temp in a curved manner. I have fixed it so that it shows max min temp instead. would like to know the center temp, please click on the temp shortcut to go to the weather screen.
viewtopic.php?p=18764#p18764
Has thanked: 205 times
Post by amazfitfacesafrica »
Very nice work, asoo. Is it possible to add animation like balance version in gtr3? Thank you.
amazfitfacesafrica wrote: 09 Aug 2024, 04:17
This clock that I made does not use custom script, so if you want to convert the animation version in "balance", you can convert it yourself. The clock only consists of white and gray colors, so after converting,It shouldn't affect the image quality in any way.
Or if you are afraid of the image quality degradation after conversion
from balance to GTR3pro, you can replace the Folder "assets"
from "Balance" replace in your .zip GTR3pro
because converting from Balance to GTR3pro only converts some scripts, such as animation.
In the image size section and x,y points remain the same. So you can use the resources in the "assets" folder from balance, replace in GTR3Pro.
thank you, asoo, I wiil do it.
