Been thanked: 1029 times
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
Hey, @SashaCX75 can You add inside editor option to use many images on digital time?, not only first 10? I mean... I want to add one image per 1 hour (1 = 1.png,... 13 = 13.png, 14 = 14.png, 24h = 24.png etc) and also for minutes and seconds? I know we can try to use some custom script, but let's be honest this way could be much better and easier to use.
@TRK88PL Standard widgets cannot do this. That's why it can be done only using JS code. I don't plan to embed such code into the editor.
rush2112
Has thanked: 119 times
Post by rush2112 »
@SashaCX75
Good morning ,
On your new updated editor tool Version 11.0 Thank You ;) when I am created a face watch ( GTR3 Pro all Value in font there are not showing on the face watch, but weather forecast value in font average is showing, Date of the Week is showing, Month is showing ) the rest like Steps, heart, Calories , battery, Distance...etc , do not show on the watch. ( only on the value font,do you have a fix for this issue, can you please clarify the reason .
@rush2112
Some functions do not work on older watch models.
You can send me a watch face where the functions don't work and I will check if it's a problem in the editor or if the functions just don't work on your model.
rush2112
Post by rush2112 »
Thanks for your reply
Superwitschi
Has thanked: 8 times
Post by Superwitschi »
Can we make a on/off script for compass?
Lattenknaller
Has thanked: 60 times
Been thanked: 132 times
Post by Lattenknaller »
Hide the Compass:
let compassnumber = 1
        let total_compass = 2
        function click_COMPASS() {
            if(compassnumber==total_compass) {
            compassnumber=1;
                UpdateCompassOne();
            else {
                compassnumber=compassnumber+1;
                if(compassnumber==2) {
                  UpdateCompassTwo();
            if(compassnumber==1) hmUI.showToast({text: 'COMPASS ON'});
            if(compassnumber==2) hmUI.showToast({text: 'COMPASS OFF'});
        // COMPASS ON
        function UpdateCompassOne(){
				normal_compass_direction_pointer_img.setProperty(hmUI.prop.VISIBLE, true);
        //COMPASS OFF
        function UpdateCompassTwo(){
				normal_compass_direction_pointer_img.setProperty(hmUI.prop.VISIBLE, false);
script as user_functions.js in the root of the WF. Create a user-defined button with
click_COMPASS();
in the editor, done
if you do not want to hide, but only start and stop, you must work with
compass.start();
and
compass.stop();
to work.
But after you return from AOD, this is back to start by default.
I would change the state of the variable like this
let compas_visible = true;
    compas_visible = !compas_visible;
    if(compas_visible) UpdateCompassOne();
    else UpdateCompassTwo();
    if(compas_visible) hmUI.showToast({text: 'COMPASS ON'});
    if(!compas_visible) hmUI.showToast({text: 'COMPASS OFF'});
Given that there can only be two states, I think that's enough.
And of course after switching on the screen or exiting the AOD mode would only trigger the compass sensor if the compas_visible == true
Superwitschi
SashaCX75 wrote: 09 Jul 2024, 11:26
Version 11.1
Mirror
rush2112
Post by rush2112 »
@SashaCX75
In your new updated Version 11.1 just asking if you did have time for GTR3 Pro fix Value in font like ,Steps, heart, Calories , battery, Distance...etc , do not show on the watch, but the ( Date of the Week is showing, Month is showing ,weather forecast value in font average is showing, weather forecast Day of the week in font is showing) on the watch GTR3 Pro .
@rush2112 Judging by your description you don't have TEXT_FONT widget working. I already wrote you that not all editor functions work on older models.
In some cases this limitation can be bypassed by using sensor data and TEXT widget. But most of the data cannot be obtained from the sensor. So you can't just replace one type of widget with another for some model. I don't plan to spend time on this.
The only thing I can do is not to display this data in the preview in the editor for some models.
@rush2112 On the GTR 3 the display of steps in font works. So it seems to be a peculiarity of your model only.
rush2112
Post by rush2112 »
@SashaCX75
Thanks for you reply but the gtr3 /gtr3 Pro they have the same version 1 , but it ok 👍 Thanks again
Cebefe
Post by Cebefe »
Hello, first of all, I would like to congratulate the author for this magnificent piece of software. Thank you very much @SashaCX75.
Secondly, could I suggest a command line option to package watchfaces? It would be very useful to use in batch scripts, for example.
Best regards.
@Cebefe What exactly do you want from the command line?
At the moment you can specify the path to the watch face as startup parameters (or drag the watch face to the afgqk of the programme) and it will be automatically unpacked when the editor is started.
Cebefe
Post by Cebefe »
Hi, specifically, I'm referring to the option of packaging watch faces without having to open the application interface.
For example, right now I have a watch face prepared in four different languages ​​in the same folder, each one with its json file. If instead of opening the interface and loading each json and packaging it one by one, a .BAT file could be used with a line like this (for example):
"D:\Watch_Face_Editor_(ZeppOS)\Watch_Face_Editor_(ZeppOS).exe" -pack_watchface "D:\WFs\*.json"
it would be very useful from my point of view.
Anyway, it's not something that's really necessary, I just thought that it could be easy to implement in future versions and it occurred to me to propose it.
WooshaQ
Post by WooshaQ »
Question, can I ude zepp os maker from amazfit website and transfer to my watch without publishng it?
Version 11.2
Mirror
Giffyfaces
Post by Giffyfaces »
is there going to be an update for the new T Rex 3 thats just been released. i have a friend who has it but doesnt know if the faces for the ultra etc will work on it through the editor
@Giffyfaces
I don't have an example of the watch face from the T-Rex 3, so I can't say anything definite yet. The watch faces from Amazfit Balance and Amazfit Cheetah Pro will most likely fit.
Omaradsl
Has thanked: 16 times
Been thanked: 8 times
Post by Omaradsl »
Hi Sasha, I have some program modification requests to make to you. I would do them myself if only the source of your file was there, but the downloads I see on this page are only exe.
1. Would it be possible to add a custom magnification of the preview window, or add a magnification greater than 2.5 x?
2.it is possible to enlarge the UI arrow icons. they are too small.
EDIT: i have 4k 32 monitor and the ui is too small for me.
@Omaradsl Interface icons are standard size and I don't plan to change them.
The source code of the editor is available and you can modify the interface to suit your own needs.
https://github.com/SashaCX75/AmazFit-Wa ... /tree/test
Maxi04
Post by Maxi04 »
Hiu, What time if you make a version with the T-Rex 3 included? :shock:
sxtywzc0408
Post by sxtywzc0408 »
How to download the program software?
