Simplify GTR3 Pro (Lattenknaller)
Has thanked: 205 times
Post by amazfitfacesafrica »
Hello, guys. Please can someone with skills from creators convert this watchface exactly as it is for GTR3 Pro because editor 11 can't convert it properly because uses ttf font and GTR3 Pro don't support ttf font. Thanks to creators for the help and thanks to Lattenknaller for his amazing works. Thank you.
https://amazfitwatchfaces.com/balance/view/1201
Has thanked: 415 times
Been thanked: 2075 times
amazfitfacesafrica wrote: 04 Jul 2024, 10:06
In my opinion The problem shouldn't be related to the editor. I think the program itself does the size conversion correctly. The problem should be that GTR3pro doesn't support TTF for some elements, so even though the program can convert the sizes correctly, It cannot be used with GTR3pro because the problem is that GTR3pro does not support TTF.
Therefore, in the case of wanting to use this dial with GTR3pro, you must create a new one by editing the custom script and creating an image font to use in place of the element that uses TTF for display.
This file is not watchface. This file contains images of numbers only.
Chr_imgae_orbitron.rar
(2.38 MiB) Downloaded 70 times
asoo wrote: 04 Jul 2024, 11:43
Hello and thank you for reply. I know that it must be from created from scratch thats why i request for help from skilled creators. I don't have the knowledge and the skills to create watchface from scratch. I like very much watchfaces with changing panels like this.
amazfitfacesafrica wrote: 04 Jul 2024, 12:08
Download GTR3pro , GTR3
This watch face may not function as original.
Because some commands cannot work on GTR3pro , GTR3 .
( ZeppOS1)
GTR3PRO:
BA-Simplify_imgFont_GTR_3_Pro.zip
(596.62 KiB) Downloaded 95 times
GTR3:
BA-Simplify_imgFont_GTR_3.zip
(630.87 KiB) Downloaded 95 times
Picajets
Post by Picajets »
Muchisimas gracias por su respuesta tan rápida saludos cordiales
Thank you, asoo!
mrbutthead
Has thanked: 60 times
Post by mrbutthead »
@asoo hi, can i have a version for gtr 4 ?
mrbutthead wrote: 14 Jul 2024, 11:18
I think GTR4 can be converted with an editor from the original file, so I think I won't do this part.
You can convert and edit the script a bit and it should work with GTR4.
After converted , script that needs editing, search in script ( user_functions.js )
and edit the x,y,w,h values ​​to match the code below, it can be used (there are 2 points)
 normal_background_bg.setProperty(hmUI.prop.MORE, {
 x: 0,
 y: 0,
 w: 466,
 h: 466,
 color: colorstring,
  normal_analog_clock_time_pointer_second.setProperty(hmUI.prop.MORE, {
 second_path: secstring,
 second_centerX: 233,
 second_centerY: 233,
 second_posX: 233,
 second_posY: 233,
Looking at the work you've uploaded, I think you can do it easily.
