Download Watch Faces to PC that are uploaded from the Zepp Store
matteo7
Post by matteo7 »
Hello everyone, I'm new here, so I apologize in advance if I make any mistakes.
I wanted to know, is there a way to download the watch faces that have been installed via the Zepp App from the store? I mean the ones that are installed directly from the Zepp dial store. I have a Balance, and I'd like to transfer the watch faces from my watch to my PC and then modify them. Does anyone know if this is possible? Thanks in advance.
Has thanked: 438 times
Been thanked: 2141 times
If you want to modify the watch face installed through the zepp app. you must be rooted your mobilePhone first to be able to access the system folder (in Android).
Or you can download directly to your PC from the web.
You can try this web.
https://mmk.pw/en/zepp_explorer/explorer/watch/
But only unbilled watch faces will be available.
matteo7
Post by matteo7 »
Thanks asoo
matteo7
Post by matteo7 »
asoo wrote: 02 May 2024, 19:26
Can you tell me the path when i search the folder of watch face? Do you know where is the folder that contain the WF? thanks again
matteo7 wrote: 11 May 2024, 15:23
Sorry, I really don't know this part.
Been thanked: 1044 times
Usually downloaded watch faces are saved in the folder /data/user/0/com.huami.watch.hmwatchmanager/files/watch_skin_local
You need root permission to access it. And not every programme can display files in this folder.
Return to “Zepp OS”
