DataBank 2a amazfit balance by Lattenknaller
Has thanked: 205 times
Post by amazfitfacesafrica »
Hello and good morning to all. Can anyone with knowledge to help me to add same 24h icon like am, pm icons with sasha editor or if there is any other way to add the 24h icon it's welcome. And how can replace altitude with uv? Thank you very much and a big thanks to Lattenknaller for the amazing dial.
https://amazfitwatchfaces.com/balance/view/166
Lattenknaller
Has thanked: 62 times
Been thanked: 168 times
Post by Lattenknaller »
Maybe you should practise a little.
There are so many works where you don't like little things, then you could change all that on your own.
First unpack the WF and look at the graphics.
In this case you would then notice, for example, that the altitude in the graphic is sym4.png. Edit the graphic (paint, gimp photoshop or other) and replace Altitude with UV. font that I used here was: "Conthrax Semibold"
For your beloved 24h icon you have to edit the background graphic and anchor the 24h there. Then the graphics for am and pm have to be edited to cover the 24h in case of a 12h operation.
I have attached the 3 finished graphics for the 24h.
Please take a look, maybe you can do the next one on your own.
24h_graphics.zip
(18.68 KiB) Downloaded 196 times
Thank you for info and for 24h graphics. Now how can add 24h graphics with editor? I will unpack the watchface and then only add the png files and then pack again then watchface?
Lattenknaller
Yes, unzip, put the 3 graphics in the assets folder, overwrite the 3 there and repack WF.
But please, please have a look at it first, maybe you will learn something. If you compare the respective graphics (old against new) you will notice how it works.
Thank you so much for all, I'm relatively new to use editor and that's why I ask questions and ask for help. Now for uv it's more complicated for me because i don't know to use paint, gimp photoshop. But thank you so much for 24h icon. Much appriciated.
Finally i add them but now have the problem that 24h icon is visible in all panels. Activity, weather and barometer page. How can we solve this problem?
Lattenknaller
I'll get one ready for you tomorrow for the GTR3Pro
I really appreciate you making it for GTR3 Pro. A thousand thanks.
Lattenknaller
Please test if everything works. I will not accept any further requests for changes.
Use it or upload it for the general public, I don't care.
DataBank2_GTR_3_Pro.zip
(797.93 KiB) Downloaded 220 times
Thank you so much, everything works fine. It's one of your best works. Best regards and have a nice day.
