Cheetah Square problem - sync custom watchface
Moderatori: asoo, Watchmens
hamaaa
Messaggio da hamaaa »
Hello. Merry christmas!
First, I apologize my unskilled English.
Please excuse me.
I'm using Cheetah Square.
I have been troubled for days about sync with some custom watch face...
At ZEPP, All normal functions work.
and Devices floating on the Bluetooth list is 'amazfit cheetah square s-xxxx'
But When I try to synchronize my watch face through other apps,
The device doesn't appear on the list.
ie. AW app, gts3/gtr4 app and so on.
When I turned on searchable, 'amazfit cheetah s' appeared on the Bluetooth list
and I have to catch it so that the device will appear in the list of other applications.
But when i try to sync the item, the progress doesn't go up... T^T
Feel heavy...
Turned off VPN...
Tried with a different devices (Samsung S23U, S23, A24)
Make several factory reset...
Installing a different version of the zepp...
Entering my own MAC address...
IT DIDN'T WORK...T^T
Thanks to SUPERSUFA,
I tried some way but...
Feel heavy...
It's the same even if it's all ground up!
I thought it was a problem with the watch face I adjusted,
so I tried putting in other files, but it didn't work....
There's nothing wrong with the official function, so I can't complain to the buyer...
If you have experienced any symptoms or problems,
please give me some advice or experiences!
Thanks and Merry christmas!
Burhafermaus
Messaggio da Burhafermaus »
i have the same problem.
Cheetah square connected with zepp, but Watchface installation failed
ZiMiZ
Messaggio da ZiMiZ »
Me too
Torna a “Device discussion”
