Gtr3 pro face watch stability?
rush2112
Has thanked: 119 times
Post by rush2112 »
Hello, maybe someone have the same problem like me, when a install a face watch on my Gtr3 pro it's all AOD ...when it's going to sleep after a turn my wrist for wake up the screen problem occurred the face watch the picture move this is the problem of stability can someone help me please 🙏
mlbl
Post by mlbl »
suggest you take a video to demonstrate. Dont understand what you're saying but if i guess you correctly are you saying the AOD watchface is "moving"? If yes this is normal to prevent burn-in on the display so it moves a bit (1-2 pixels) in random directions. This is not a bug or stability issue. ALL smartwatches that is worth half a salt does this even from the old days of Android Wear/Wear OS many years ago till Amazfit watches.
If that's not what you mean - show us a video for clearer understanding. Thanks
rush2112
Post by rush2112 »
OK
thanks for your help your did confirm that is normal :)
mlbl
Post by mlbl »
welcome. glad that cleared it up :)
