Has thanked: 14 times
Been thanked: 1044 times
v18.1
Version 18.1
bfermar
Post by bfermar »
Great job!!! @SashaCX75...Would it be possible in a future update of the editor to be able to add the barometric height values? Regards
wp456
Post by wp456 »
Is it because of the specifics of this watchface or an issue in the editor that this one cannot be meaningfully opened with the editor?
(It just shows the assets but nothing more, no preview, no settings)
https://amazfitwatchfaces.com/gtr/view/31947
K4rol
Post by K4rol »
how to easly change the red color to blue in all images?
bfermar Watch faces do not have access to height values. Given that this value varies greatly depending on the weather, I consider it absolutely useless.
K4rol To change the colors on the images, use any graphic editor, such as GIMP.
ZduneX25
Been thanked: 6 times
Post by ZduneX25 »
SashaCX75 have you ever heard about gtr3 smooth seconds implementation that does not work on trex2? i received several reports now, but i always thought trex2 and gtr3 share the same code, they both run zeppos 1.0 (no such problem on gtr3pro for example)
ZduneX25 Should be ZeppOS 1.0 but works similar to ZeppOS 2.0
ZduneX25
Post by ZduneX25 »
I heard they added external bluetooth devices (HR belt etc) support in TREX 2 firmware so it is probably mix of both zeppos 1 and 2 now.
Version 7.1
Mirror
Guydu91
Has thanked: 59 times
Post by Guydu91 »
Hello Sasha,
I'd like to create a watch face with the following shortcuts:
- Membership cards
- Compass
- Alexa
- Diary and/or Calendar
Could you give me the necessary codes for this?
Thank you in advance for your answer.
Best regards.
PS1: I haven't seen these questions asked in the previous threads... but I may have missed something...
PS2: Congratulations again for this superb work!!
Guydu91
Try these commands.
hmApp.startApp({ appid: 1, url: 'CompassScreen', native: true })
hmApp.startApp({ appid: 1, url: 'OnlineVADScreen', native: true })
hmApp.startApp({ appid: 1, url: 'ScheduleCalScreen', native: true })
hmApp.startApp({ appid: 1, url: 'ScheduleListScreen', native: true })
Guydu91
Post by Guydu91 »
Thank you Sasha for your quick answer.
I'll try these commands as soon as possible.
Best regards.
joselito1996
Post by joselito1996 »
SashaCX75 wrote: 21 Mar 2023, 19:35
@Guydu91
Try these commands.
Good morning, first of all thank you for the program, as it works very well, but I would like to know where you can get all the shortcuts you mention, so I can experiment, I understand that there will be a list of the names of the commands somewhere, right?
gildo52
Post by gildo52 »
Is It possibile to have a "tutorial" about usage of "editable element" ?
Version 7.2
Mirror
ivblumen
Post by ivblumen »
hello, is there or will there be support for GTR Mini on the editor? Someone said creating faces for Falcon should work, but another person reported they were not compatible.
Thanks and congratulations for the wonderful software.
joselito1996
joselito1996 wrote: 24 Mar 2023, 13:53
@Guydu91
Try these commands.
But I would like to be able to see the possibilities of all the codes out there, even downloaded apps, where do you get those codes from?
joselito1996 wrote: 05 Apr 2023, 00:30
This data is taken from the available watch firmware. The list can be viewed here, but it is better to search for this information in your language.
https://melianmiko-board.notion.site/61 ... 511b8149e3
Guydu91
Post by Guydu91 »
Hello Sasha,
I can't get the shortcut for Alexa to work, the watch face is unresponsive while the other shortcuts work.
Did I forget something?
Best regards.
Guy.
Guydu91 I have Alexa trying to start but a message pops up saying there is no account connected in Zepp.
Guydu91
Post by Guydu91 »
SashaCX75 wrote: 09 Apr 2023, 06:53
@Guydu91 I have Alexa trying to start but a message pops up saying there is no account connected in Zepp.
As far as I'm concerned, it's rather as if there were no shortcut: if I click on the shortcut I created, nothing happens.
On the other hand, I can use Alexa when I look for the function in the watch menu...
Can't we use another shortcut?
Guydu91
Post by Guydu91 »
Hello Sasha,
The problem is solved, the shortcut to Alexa is correct: you just have to install the Alexa application on the phone and give access in the Zepp application... and it works!
Best regards.
Guy. :D
Hviegas
Post by Hviegas »
Hi, it works very well for me, but i have two questios:
- how to create a shortcut for brightness
- why shortcut for PAI is not working on amazfit band 7?
Guydu91
Post by Guydu91 »
Hviegas wrote: 12 Apr 2023, 16:13
The shortcut for the brightness is the following: {url: 'Settings_lightAdjustScreen', native: true} but you will find all the codes for the different shortcuts in the link indicated by Sasha a little higher.
For the PAI shortcut, the watchface editor provides for it (I have already integrated it into the CW4U_SPORT_COLORS watchface for GTS4 and GTS4 Mini).
So it should work normally unless Amazfit Band 7 needs special setting.
To see maybe in the Zepp application...
Best regards.
Lukimator
Post by Lukimator »
SashaCX75 wrote: 12 Mar 2023, 17:39
@bfermar Watch faces do not have access to height values. Given that this value varies greatly depending on the weather, I consider it absolutely useless.
Is that correct? I have 2 or 3 watch faces displaying altitude installed on my T-Rex 2. I don't know how they made those though
