belikeKara
Post by belikeKara »
Now that Amazfit supports the calendar integration in Zepp, is there any chance of adding "Calendar" as a shortcut. Thanks, Mike
belikeKara Using standard tools, it is impossible to make a shortcut for the calendar either in my editor or in the official editor. But there are workarounds, for this you will need to manually edit the watch face code.
belikeKara
Thank you for the quick reply. I created a Captain Marvel watchface animation. Everything appeared fine except when I downloaded it to my watch there was no animation. I used to do animations all the time for the Amazfit X. You can view the animation here. https://drive.google.com/file/d/17ViXA- ... sp=sharing
If you want to look at the zip file it is stored at the link below with the name of CaptainMarvel.
https://amazfitwatchfaces.com/gtr/view/23798
Been thanked: 2122 times
belikeKara wrote: 29 Aug 2022, 21:15
The name for animation "frame by frame" must to start at 0 ( anim_0 )
Exa. (Fixed)
CaptainMarvel.zip
(653.59 KiB) Downloaded 263 times
belikeKara
Thank you for the help. The instructions were very clear, my interpretation was a bit foggy.
Superwitschi
Has thanked: 8 times
Post by Superwitschi »
SashaCX75, will you make in the future a editor for GTR 4?
Superwitschi
Support for GTR 4 will be added as soon as it becomes possible to test the work of the created watch faces on a real device.
Superwitschi
SashaCX75, thanks. I ordered my GTR 4 yesterday.
If someone is ready to test the dials on the GTR 4 write in private messages.
vjna
Post by vjna »
i have a t-rex 2
I have made an animation of the second hand
but I don't know if I have set the duration of the animation correctly
I have tried to do it with a stopwatch and the closest speed I have achieved is 51
how should the "loop animation speed" box be interpreted?
How is that animation speed measured?
Version 5.0
Mirror
The watch faces from the GTS 3 should fit the GTS 4, but I haven't been able to verify this.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
If I manage to confirm this information, I will let you know.
kwakykwaky1
Post by kwakykwaky1 »
great work again. ;)
Thanks friend ;) ;)
And I send greetings from the Czech Republic
Dru79
Post by Dru79 »
How to avoid deteriorating the quality of the graphics in the finished face?
Images are converted to a format using a color map (256 colors). Therefore, smooth gradients and shadow effects greatly degrade the quality of the image in the watch face.
Dru79
Post by Dru79 »
I think that editor for GTR2 doesn't have that issue.
Powerade001
Has thanked: 12 times
Post by Powerade001 »
Hi!
Thank you again for this great tool!
I received my GTR4 yesterday and immediately tried custom faces build with this face editor. All is working except for aod which displays default built-in aod dial instead of following current watch face. I tried several custom watchfaces with the same result.
Powerade001 wrote: 16 Sep 2022, 11:51
Hi!
I'm not sure , that your problem is caused by the settings on the watch or not. ( I don't have a GTR4.)
I am using GTR3, in GTR3 there is a section for display settings, AOD screen.
It can be set to display "Follow watch face" or the default built-in.
Setting --> Display --> Always on --> Always on style --> Follow watch face
Can you try the test in GTR4 to see if there is this section?
Powerade001
Hi Asoo!
Thanks for your reply. My watch is already set to follow watch face.
My previous watch was a Gtr 3 Pro and have had no problem with custom watch watch. All I did was convert all my previous watchfaces to Gtr4 with the new SachaCX's 5.0 tool. But aod does not work. I even tried watch faces from Amazwatchfaces.com in the new Gtr4 section and no success from trying a few of them. They all revert to default built-in aod. If I choose an Amazfit watch face (already on watch or Amazfit store), it will use the aod that follows that watchface.
Powerade001 wrote: 16 Sep 2022, 16:22
Hi Asoo!
Interfere , Please help of the test. This two files
Can The both files display full AOD on GTR4 of the dial correctly or not ?
FAOD_GTR4_official_editor.zip
(1008.96 KiB) Downloaded 264 times
FAOD_GTR4.zip
(299.83 KiB) Downloaded 264 times
Thank you so much
Powerade001
Hi Asoo,
I tested both files. The one created with official editor worked perfectly. Aod followed the watchface. The other file did not (the 300kb one).
Powerade001 wrote: 17 Sep 2022, 01:24
Hi Asoo,
Probably because the GTR4's FW has a reading the script a different AOD section than GTR3, I can't test this. because I don't have a GTR4
I've reported what happened to SashaCX75 , but I'm not sure can fix or not.
Please try to test this file again.
If it can't show, I probably won't be able to continue either.
-- Delete file attachments because it not work --
Powerade001
Sorry. That file did not work. It reverts to build-in aod. Thanks for your help!
Powerade001
Try this file.
If it doesn’t help and you are still ready to test the watch faces, then after the weekend I will try to make a simpler watch face, on which it will be easier to find the differences between the working and non-working versions.
testAOD.zip
(299.79 KiB) Downloaded 322 times
Powerade001
Hi all!
TestAOD2 from Asoo did not work but testAOD from SachaCX did work. Aod followed watchface.
I you need me to test more, I am more than happy to help!
Allan
