changing face to imperial [gtr 3 pro]
i downloaded a watchface to my gtr 3 pro using amazefaces app on my iphone but the distance ran is in km and i live in the usa is there anyway to change it? i already checked in the zepp app and its set to imperial.
- GIK-Team
- root
- Has thanked: 1184 times
- Been thanked: 281 times
Can you show what watch faces you use?Qasimja wrote: 26 Jul 2022, 18:52i downloaded a watchface to my gtr 3 pro using amazefaces app on my iphone but the distance ran is in km and i live in the usa is there anyway to change it? i already checked in the zepp app and its set to imperial.
- GIK-Team
- root
This watch face is designed to display distance in kilometers, so the options will not help you change this setting.
is there anyway i can filter on the amazefaces app to show watches that have miles because i havent seen one yet for the gtr 3 pro that has miles only kilometers
- GIK-Team
- root
When you switch in the settings, does the number change? I see that in the dial of the “km” label this is a picture, but the field itself takes the system settings. This means that the digital value must change.Qasimja wrote: 27 Jul 2022, 14:21is there anyway i can filter on the amazefaces app to show watches that have miles because i havent seen one yet for the gtr 3 pro that has miles only kilometers
yea it shows i was just wanting to switch the "KM" to "MI" but i guess thats not possible
- GIK-Team
- root
Is the distance correct? I understand correctly that the problem is only in the picture that shows “KM”?Qasimja wrote: 27 Jul 2022, 20:47yea it shows i was just wanting to switch the "KM" to "MI" but i guess thats not possible
yea thats basically what i was asking about just curious if it could be changed to "MI"
- GIK-Team
- root
Moved your topic to the appropriate forum.Qasimja wrote: 28 Jul 2022, 00:37yea thats basically what i was asking about just curious if it could be changed to "MI"
asoo, could you help me with this question, please? Thanks!
- Has thanked: 441 times
Of course, I'd be more than happy to help.
- This watchface can switch between Km and Mi , after you change on your zepp- This watchface has added a script to show Mi. by adding with manual by use "notepad" for edit index.json
By those who are interested can add themselves by adding the command line as below.
normal_distance_text_text_img = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
x: 65,
y: 372,
font_array: ["0069.png","0070.png","0071.png","0072.png","0073.png","0074.png","0075.png","0076.png","0077.png","0078.png"],
padding: false,
h_space: -8,
unit_sc: '0097.png',
unit_tc: '0097.png',
unit_en: '0097.png',
// script for show Mi after you select Mi on zepp
imperial_unit_sc:"0097-1.png",
imperial_unit_tc:"0097-1.png",
imperial_unit_en:"0097-1.png",
dot_image: '0096.png',
align_h: hmUI.align.CENTER_H,
type: hmUI.data_type.DISTANCE,
});ͼͽ To request please use the interrelated forum in action ͼͽ
thank you
