changing face to imperial [gtr 3 pro]
Qasimja
Post by Qasimja »
i downloaded a watchface to my gtr 3 pro using amazefaces app on my iphone but the distance ran is in km and i live in the usa is there anyway to change it? i already checked in the zepp app and its set to imperial.
Has thanked: 1184 times
Been thanked: 281 times
Qasimja wrote: 26 Jul 2022, 18:52
Can you show what watch faces you use?
This watch face is designed to display distance in kilometers, so the options will not help you change this setting.
Qasimja
Post by Qasimja »
is there anyway i can filter on the amazefaces app to show watches that have miles because i havent seen one yet for the gtr 3 pro that has miles only kilometers
Qasimja wrote: 27 Jul 2022, 14:21
When you switch in the settings, does the number change? I see that in the dial of the “km” label this is a picture, but the field itself takes the system settings. This means that the digital value must change.
Qasimja
Post by Qasimja »
yea it shows i was just wanting to switch the "KM" to "MI" but i guess thats not possible
Qasimja wrote: 27 Jul 2022, 20:47
Is the distance correct? I understand correctly that the problem is only in the picture that shows “KM”?
Qasimja
Post by Qasimja »
GIK-Team wrote: 27 Jul 2022, 22:33
yea thats basically what i was asking about just curious if it could be changed to "MI"
Qasimja wrote: 28 Jul 2022, 00:37
Moved your topic to the appropriate forum.
asoo, could you help me with this question, please? Thanks!
Has thanked: 441 times
Been thanked: 2142 times
GIK-Team wrote: 28 Jul 2022, 08:40
@asoo, could you help me with this question, please? Thanks!
Of course, I'd be more than happy to help.
V004_Km_Mi.zip
(442.56 KiB) Downloaded 63 times
- This watchface can switch between Km and Mi , after you change on your zepp
- This watchface has added a script to show Mi. by adding with manual by use "notepad" for edit index.json
By those who are interested can add themselves by adding the command line as below.
            normal_distance_text_text_img = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
              x: 65,
              y: 372,
              font_array: ["0069.png","0070.png","0071.png","0072.png","0073.png","0074.png","0075.png","0076.png","0077.png","0078.png"],
              padding: false,
              h_space: -8,
              unit_sc: '0097.png',
              unit_tc: '0097.png',
              unit_en: '0097.png',
// script for show Mi after you select Mi on zepp
	imperial_unit_sc:"0097-1.png",
	imperial_unit_tc:"0097-1.png",
	imperial_unit_en:"0097-1.png",
              dot_image: '0096.png',
              align_h: hmUI.align.CENTER_H,
              type: hmUI.data_type.DISTANCE,
Qasimja
Post by Qasimja »
asoo wrote: 28 Jul 2022, 09:45
thank you
