Amazfit T-Rex 2
59chevy
Amazfit T-Rex 2
Post by 59chevy »
Is anyone else having problems downloading watch faces to the T-Rex 2?
Crespo21
Post by Crespo21 »
yes, failed. it keep connecting in the apps.
bh7mtz
Post by bh7mtz »
It is recommended to use gtr3 application software, which is universal
dbarber1
Post by dbarber1 »
For installing watchfaces you can use the direct sync feature in this app that has GTR 3 watchfaces to transfer it to the watch. It detects the watch as a T-Rex 2, and most if not all of the GTR 3 watchfaces should work on the watch as well. I have transferred a couple of them to the watch and they seem to work just fine. The app is called Amazfit GTR 3 Pro GTS 3 Faces and the developer of the app is Mi Band Watch Face Makers. Here is the link to the app directly, all you have to do is add the first part of the Google Play Store link to is as it's not going to let me post the full link
store/apps/details?id=asn.ark.amazfitwatches
The app will also allow you to install watchfaces you have downloaded as well, using the direct sync feature. Hope this helps
CASIONFAN2021
Post by CASIONFAN2021 »
I managed to install watch faces to my T REX 2 with no issues using the app - thanks for the links
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
I had to manually enter the MAC address then it was fine.
Nightsky74
Post by Nightsky74 »
Where do u enter the mac address?
Return to “Device discussion”
