How can I put my watchface in my mi band 6
Hi!, how can I put my watchface in my mi band 6 now that the application is changed? I change the file in the folder "com.xiaomi.wearable/files/WatchFace" but it doesn't work anymore D:
- GIK-Team
- root
- Has thanked: 1162 times
- Been thanked: 278 times
If you're posting in threads that don't match your question, you probably won't get help.Sladeth wrote: 08 Jun 2022, 03:40Hi!, how can I put my watchface in my mi band 6 now that the application is changed? I change the file in the folder "com.xiaomi.wearable/files/WatchFace" but it doesn't work anymore D:
GIK-Team wrote: 08 Jun 2022, 07:45If you're posting in threads that don't match your question, you probably won't get help.Sladeth wrote: 08 Jun 2022, 03:40Hi!, how can I put my watchface in my mi band 6 now that the application is changed? I change the file in the folder "com.xiaomi.wearable/files/WatchFace" but it doesn't work anymore D:
oh, i'm sorry, where can i ask this? (I get the watchface .bin by the WFTool btw)
- GIK-Team
- root
Please specify which app you are talking about. Thanks!Sladeth wrote: 09 Jun 2022, 14:59GIK-Team wrote: 08 Jun 2022, 07:45If you're posting in threads that don't match your question, you probably won't get help.Sladeth wrote: 08 Jun 2022, 03:40Hi!, how can I put my watchface in my mi band 6 now that the application is changed? I change the file in the folder "com.xiaomi.wearable/files/WatchFace" but it doesn't work anymore D:
- GIK-Team
- root
I have separated your posts into a separate topic.
