One request for [GTS]
erdogankr06
Post by erdogankr06 »
Hello, today I found the watch interface in the photo below in the amazfaces application, but it is compatible with amazfit gts 3.
I want you to make this watchface for the model with amazfit GTS. I don't have the knowledge or skills for this. I would be very happy if you help me.
Thank you everyone in advance.
https://amazfitwatchfaces.com/gts/view/7577
https://amazfitwatchfaces.com/gts/view/7575
Been thanked: 2120 times
Please read carefully
Not tested on real devices. because I don't have GTS
All tests are performed on the Program editor only.
viewtopic.php?p=3789#p3789
If it doesn't work, please report it. I will delete it out.
This is a test of my GTS build only.
I thought I wouldn't do it again if I wasn't interested that watchface
Note :
If anyone wants further improvements from what I do. Please do it by yourself From this GTS resource
Image Image
GTS-digital_packed_zip.bin
(465.72 KiB) Downloaded 53 times
GTS_packed.bin
(1.24 MiB) Downloaded 45 times
erdogankr06
Thank you very much. I will try and comment again. :)
erdogankr06
asoo wrote: 10 Feb 2022, 06:04
Note :
Image Image
GTS_packed.bin
I applied the watchfaces in the link you gave and the result is very successful. It works very well. Thank you very much again. You are perfect.
