Been thanked: 1030 times
Dema
Post by Dema »
Hi gengtrex, if you really wanted to use the .bin file look at this message
Mazaias wrote: 14 Jan 2022, 11:25
gengtrex
Post by gengtrex »
FeRu wrote: 16 Jan 2022, 10:07
gengtrex wrote: 16 Jan 2022, 08:07
hi sasha. @SashaCX75
just a quick question.
thanks a lot in advance.
beside uploading the .zip via amazface.
can i load it to the watch directly?
gengtrex
Post by gengtrex »
Dema wrote: 16 Jan 2022, 11:40
thanks a lot.
i have tried change zip to bin and uploaded thru the app 'notify for amazfit' to the watch but got an error.
(i used to do this way with gt1 gt2 t-rex.)
Dema
Post by Dema »
gengtrex wrote: 16 Jan 2022, 13:09
Hi @gengtrex, if you really wanted to use the .bin file look at this message
thanks a lot.
If you want install it on your watch you can use amazfaces app. That's really easy
Dema
Post by Dema »
gengtrex I lost some message, sorry...
Through the amazfaces app you must upload the zip file.
Otherwise, If you want use bin file, you must "open" it by your (or an alternative) android file manager and he should propose you to open it by amazfaces app..
I hope i was clear
Dema
Post by Dema »
For who was interested, regarding .bin file installation, i don't know why, but if you send the .bin file to a telegram chat (with yourself for example) and then try to open it through telegram, even if your file manager doesn't show you the amazfaces option, telegram do. ;)
FeRu
Has thanked: 14 times
Been thanked: 8 times
Post by FeRu »
Is there any solution how to make that pointer in heart rate section or any other section to be above image progres (I mean to have higher priority of showing)?
Because right now in some WFs when I want add pointer to Heart rate progress in huami editor or in this editor pointer is hiding below image progres :(
Iy's possible to change priority of showing elements in index.jr file?
In previous editor pointer was always above other progress info (linear,curcular or image)
Has thanked: 415 times
Been thanked: 2075 times
FeRu wrote: 17 Jan 2022, 08:01
Click left mouse and hold on the element that you want to change layer level then move that element to layer your layer level you want
Dema
Post by Dema »
if I'm not wrong, you can drag the elements on top to give priority of visibility
FeRu
Post by FeRu »
asoo wrote: 17 Jan 2022, 08:29
Thanks Asoo, SashaCX75 just send me info about this also.
But how do this in Huami editor? The same option is not working there and pointer is below iamge progres there so I think that it could be done in index.jr file manually maybe....
FeRu wrote: 17 Jan 2022, 08:48
Thanks @Asoo, SashaCX75 just send me info about this also.
I answered the previous question Since you asked the problem in the topic of Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3).
If you are referring to the scripting sequence to achieve the above effect, you can refer to the example below.
 normal_heart_rate_text_text_img = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
              x: 299,
              y: 354,
              font_array: ["B-no01.png","B-no02.png","B-no03.png","B-no04.png","B-no05.png","B-no06.png","B-no07.png","B-no08.png","B-no09.png","B-no10.png"],
              padding: false,
              h_space: 4,
              invalid_image: 'B-no12.png',
              align_h: hmUI.align.LEFT,
              type: hmUI.data_type.HEART,
              x: 248,
              y: 359,
              image_array: ["Pulse01.png","Pulse02.png","Pulse03.png","Pulse04.png","Pulse05.png","Pulse06.png"],
              image_length: 6,
            normal_heart_rate_pointer_progress_img_pointer = hmUI.createWidget(hmUI.widget.IMG_POINTER, {
              src: 'h0006.png',
              center_x: 260,
              center_y: 370,
              x: 10,
              y: 40,
              start_angle: -90,
              end_angle: 90,
As I understand it, if you want an element to be at the top you must write a script at the bottom.
PS. If possible I recommend Open a new topic to avoid confusion in answering.
jorixine
Post by jorixine »
hey guys, sorry the lame question...
which json file should I open to edit a downloaded watch face?
Dema
Post by Dema »
jorixine wrote: 18 Jan 2022, 19:52
You should unpack the zip file with the editor
16jchex
Post by 16jchex »
Good afternoon: When I create a sphere and add the DND element to it, in addition to the icon or image that I have put on it, when activating DND on the clock, another DND symbol appears on approximately 240 X 50 that the clock itself provides, I don't know if It will be a bug in the sashaCX75 software, or it will be a problem in the GTR 3 Pro firmware.
Sorry for my English. Thank you and greetings.
FeRu
Post by FeRu »
16jchex wrote: 19 Jan 2022, 18:44
This is not error of Editor or problem of GTR3 Zepp OS. This is system icon displayed on any watchface.
16jchex
Post by 16jchex »
Understood. Thanks FeRu for your quick reply. All the best.
Hal9199
Post by Hal9199 »
Hello, how to install WF on iphone. Thank you.
Hal9199
Post by Hal9199 »
How to convert a WF made for GTR to WF for GTR 3 PRO?
Can I send you the files?
ThomasAn.
Post by ThomasAn. »
VIKTOR_TSVETKOV
Post by VIKTOR_TSVETKOV »
Can you add animation feature and system font option?
ThomasAn. wrote: 26 Jan 2022, 03:09
VIKTOR_TSVETKOV wrote: 26 Jan 2022, 15:00
I have plans to add animation.
I do not plan to add the ability to use the system font to the editor. With the capabilities that the system font has, I do not see the point in this.
jerrywm2
Post by jerrywm2 »
Hello @SashaCX75!
Two quick questions:
1. Is there a place (PayPal, Venmo, etc.) where we can send you a tip for all of your work?
2. Do you have an idea when you will have an update that includes the weather? I can't wait to use it to design some faces.
Thank you!
MattP85
Post by MattP85 »
Hello I have a question : is it possible to make some animated background like here :
https://amazfitwatchfaces.com/gtr/view/20836
thank you
jerrywm2
Users browsing this forum: legendoflegacy and 1 guest
