Search found 2 matches
Return
by asoo
07 Jun 2025, 02:32
Jump to forum
Jump to topic
Re: How do I upload my watch face made in Zepp Watchface?
From my test, the device.zip file from Zepp "watchface maker"
can be used to generate QR code normally and can be linked to my Balance (the file from "Zepp Watchface maker" in Balnace is the same as Trex3)
So I recommend you to attach the file that has the problem
so that people who want to help ...
by SashaCX75
07 Jun 2025, 05:20
Jump to forum
Jump to topic
When exporting from Zepp Watchface Maker, switch off all models except yours. Then there will be only one zpk file inside the resulting file. In this zpk file take device.zip, this will be your watch face. If you upload it to this site and install it on the watch using qr code, refresh the page ...
