Joker18 You can't do it in the editor.
You need to write additional code yourself. You need to get the time of sunrise and sunset from the weather sensor. Knowing this time, calculate the rotation angle of each pointer and rotate it.
I don't understand the purpose of the middle scale on your image ...
Search found 2 matches
- 17 Nov 2024, 13:19
- Jump to forum
- Jump to topic
- 17 Nov 2024, 14:31
- Jump to forum
- Jump to topic
Joker18 Using images may not be the right solution. In some cities, the time does not correspond to their geographical time zone. Some countries have summer time and some do not. Even if cities are in the same time zone sunrise and sunset times can differ by an hour. So this way you can only make a ...
