I have a lot of install watchfaces issues, the previous version was working fine.
When is open the app i cant install any faces before looking to some ads.
When i try to install it wont react. i need to open the zepp app, close the it, open the amazfitwatchfaces app,
turn off bluetooth turn it back ...
Search found 7 matches
- 12 Feb 2023, 18:13
- Jump to forum
- Jump to topic
Re: AmazFaces for iOS [Support]
Thanks for the reply, I will try to fix this problem in the next update.
- 13 Feb 2023, 12:34
- Jump to forum
- Jump to topic
Thanks for the message, you can help in Testflight
https://testflight.apple.com/join/4hBEKHHg
Day two will be an update in testflight, you can check the fixes.
App version (Stable) 4.0.284
Watch model: Amazfit T Rex Pro
Phone model: iPhone 13
OS version: 16.2
The nag message about watching ...
OS version: 16.2
- 15 Feb 2023, 12:18
- Jump to forum
- Jump to topic
App version: 4.0 (ios)
Watch model: Amazfit GTS 2 mini
Phone model: iPhone XS max
OS version: IOS 16.2
after the app update, I can't install any watch faces whatever I try, no amount of bluetooth restart or app restart or reinstalling is helping me to apply any watchface, always opening the issue ...
- 22 Feb 2023, 14:34
- Jump to forum
- Jump to topic
Try beta version
after the app update, I can't install any watch faces whatever I try, no amount of bluetooth restart or app restart or reinstalling ...
- 23 Feb 2023, 18:11
- Jump to forum
- Jump to topic
I tried the new version in the app store and it is working fine,
Can you make a paid version without ads?
- 24 Feb 2023, 07:13
- Jump to forum
- Jump to topic
Do you have problems with installation or with advertising, and what model of the watch?
Any update on the iOS fix? I'm still dead in the water with the Ad / nag screen. I haven't replaced my watch face in two weeks. I'm starting to get withdrawal DT's. My hands shake and I can't concentrate ...
