If you have any questions about the GTS 2 mini, it is better to contact the neFAST user. As far as I know, he has made a lot of progress in terms of working with these dials. Maybe he wants to create a separate thread on this forum.
Those who have problems installing python can use this utility. It ...
Se encontraron 4 coincidencias
- 09 Oct 2021, 14:14
- Jump to forum
- Jump to topic
- 14 Abr 2022, 13:29
- Jump to forum
- Jump to topic
Re: Request for GTS2 mini
Bip 3 , gts2 mini , Bip U
You can try to do by yourself by use Editor on web.
https://tnxec2.github.io/amazfit-gts2mini-watchface-react/
https://github.com/Tnxec2/amazfit-gts2mini-watchface-react/archive/refs/heads/gts2mini.zip
if you want to see new version ...
- 20 Jun 2022, 04:18
- Jump to forum
- Jump to topic
Thank you so much and I finally made it!
I changed my png format from using palette to truecolor.
also about my jason file, I found that I didin't add preview block. what a laugh...
- 19 Jul 2022, 15:27
- Jump to forum
- Jump to topic
Pack all resource in the folder to make BIN
- copy main_mini.exe to the folder where the .json that you want to pack.
command line for pack to BIN
Código: Seleccionar todo
main_mini.exe --gts2mini --file filename.json
