Few informations for converting Bip watchfaces to Bip S
Infos and Bip S tool taken from here: 4pda.ru/forum/index.php?showtopic=988136
Bip S Tools Alpha 230420 mirrored to my yadisk: yadi.sk/d/I1tDQ3PbDIupWA
Converting from Bip or creating new is nearly the same. No Bip S watchface editor as I ...
Search found 5 matches
- 05 Jun 2020, 11:17
- Jump to forum
- Jump to topic
- 09 Jun 2020, 21:35
- Jump to forum
- Jump to topic
Re: Create Bip S watchface or convert from Bip
There is no watchface editor for Bip S as i mentioned. If you put Bip S format json to Bip editor, it will throw errors because they are not compatible.
Make normal Bip watchface with Bip editor, save json, and finally edit json manually to add "number" things with Notepad++ or similar editor.
Then ...
Then ...
- 18 Jun 2020, 23:58
- Jump to forum
- Jump to topic
When I edit the JSON in Notepad++ and put it into the AmazfitBipS_Tools_alpha_230420 tool, it produces me everything but it shows me an animated GIF without Steps and Pulse.
It's the same when I upload it onto my Bip S, can someone please check it out and explain what I am doing wrong? :roll:
I ...
- 13 Jul 2021, 18:54
- Jump to forum
- Jump to topic
Re: Moon / Bluetooth / bell / padlocker items
Moon=Do not disturb mode (On/Off)
Bell=Alarm (Set or not)
Bluetooth=Connection to phone
Padlock=Screen locked (Touch disabled)
- 28 May 2021, 03:05
- Jump to forum
- Jump to topic
Re: Port Request from Bip to Bip S
Hi Wiloman,
You are the best! Thanks a lot.
I had some issues to install it via Notity, but finally it worked!
Everything works fine, except the grafical bar of the battery measurement. It always shows red/ almost empty. But this is minor minor for me, the number aside is correct.
I assume, the ...
