Se encontraron 2 coincidencias
Return
por ebs
30 Jul 2019, 20:24
Jump to forum
Jump to topic
Re: True 12hr (3/4 digit display)
The BIP firmware makes creating true 12-hour watchfaces harder than it should be.
You have to make a set of hours digit images that are 2 digits wide, with transparent portions that get overwritten.
Then you have to change the .json file to use the new images for the hours tens and units digits ...
por asoo
04 Ago 2019, 12:34
Jump to forum
Jump to topic
Re: Change Font Colour
https://amazfitwatchfaces.com/bip/view/16262
I am trying to change the font colour of the above watchface so that the minutes match the hour (I don't like orange). I tried changing the imageindex of the minutes to the same as the hour but it would not allow me to export json. Any ideas? I guess I ...
